GM Gen 4 conversion including LS - Page 51 - Defender Source
Old December 29th, 2015, 11:05 AM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
Merry Christmas to me and my Defender!
I got some nice shiny stuff from St. Nick!
Anyone have the jig they can ship me on my dime for the weld in motor mounts? Or measurements would work also. Thanks!
Old December 29th, 2015, 12:20 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Originally Posted by 86Defend110 View Post
My original LT230 is a 20D so I believe it is a 1.6. I am going to find a Disco 1 with 1.2 ratio and put that in with the LS3 with 33" tires.
I have a tcase off a D1 sitting in Tucson…
Old December 29th, 2015, 01:02 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
I burned a couple yesterday. I will send one today.
Old December 29th, 2015, 02:24 PM
skitzy's Avatar
skitzy
Nick
91 D90 2.5NA doing LS Gen IV Thing
Hi St. Nick,
Please also send a burned template to me too.
I also need one each of the following (include all together):
-accessory drive bracket (alt/ps)
-Lokar shifter bracket
-clutch pedal block off plate
Also please remind me if this is needed for' 91 Ninety LHD MOD with existing LT230 1.461 ratio and your adapter / adaptor:
-diff lock lever
Thanks.
Old December 29th, 2015, 10:35 PM
Iirc southwest rovers / rob dassler has one installed in a disco.
Old December 30th, 2015, 12:07 AM
skitzy's Avatar
skitzy
Nick
Originally Posted by nmarkiw View Post
The diff lock levers arrived today.
Ok please put one (1) "diff lock lever" my pile too, with all the above. TY
Old December 31st, 2015, 06:09 AM
Raven81's Avatar
Raven81
Todd
1997 NAS D90
Nick,
I shot ya a couple PMs when you get time. Just looking for more data on sourcing/pricing new Gen V drivetrain components. Also, wondering if your adapter will fit the new 8L90E boxes? Thanks!
Old December 31st, 2015, 01:36 PM
Landy_Andy's Avatar
Landy_Andy
Andy
X-post from the Gen III threrad.....
Originally Posted by Landy_Andy View Post
Fixed the crappy looking fuel lines with some 180 degree fittings
Just a quick follow up on the fuel lines, one of the guys on another forum pointed out (after I posted this pic) that you can flip the fuel rails by trimming the plastic tabs off the plenum to get the connections pointing backwards again on the drivers side.
Would save a few $ on the 180 degree fittings....
Old January 4th, 2016, 01:52 AM
skitzy's Avatar
skitzy
Nick
Wilson FAST LSX 92mm Intake Manifold?
Re-use the truck LH6 intake manifold for Defender LS conversion, use a low profile intake manifold, or this Wilson FAST LSX 92mm Intake Manifold? FAST LSX 92mm.
Old January 4th, 2016, 09:42 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Attachment 138462
Thanks.... I'll PM you my address..... nice 'after' Christmas present
Old January 4th, 2016, 11:10 PM
UL1700
James
Defender 50th
Attachment 138462
Holy crap! would need to be very convinced about the performance / looks to spend that over using the stock car manifold! I thought I was being extravagant purchasing the ceramic coated Hooker manifolds. I was building my own but as Summit had 60 odd bucks off I took the plunge. I don't know what the actual benefits of having the ceramic coating will be but I figure with the air intake sitting at the back of the engine bay if it does save a few degrees of engine bay temperature then it has to be a good thing... ooh top tip for the bonnet, if like me you had to remove the bottom mount for the crappy stay that LR provided, P38 bonnet struts fit perfectly. Simply rob the bonnet struts, the bolt on brackets and grab two spare balls off the top tailgate. To fit, set the balls as far back as you can on the wing before the angle changes. I used a right angle drill and short drill bit for this. Set your opening height (don't go to far as the hinges will open) and rivet the brackets to the bonnet lip (the brackets need slight trimming and new holes drilling). Only took about 30 mins with the correct tools and works perfectly
20160105_143536 by James Elphick, on Flickr
20151231_140508 by James Elphick, on Flickr
Old January 5th, 2016, 07:12 AM
phoenix37's Avatar
phoenix37
john
looks great James... drive it yet?
Old January 5th, 2016, 04:04 PM
UL1700
James
Defender 50th
Close, manifolds and throttle pedal are clearing customs but it does run Can't wait to get it out of the workshop, give it a clean and take if for a drive!
Old January 7th, 2016, 12:15 PM
Mostlymonki
Matt
1998 130, 1988 110
fuel tank question:
if i used a plastic TD5 tank instead of the steel earlier one, would the fuel pump etc. listed in Nick's BoM still work?
I might be getting a galv chassis made especially for the conversion, so have a choice for tank mountings...
Old January 9th, 2016, 12:58 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Turn Key Engine Supply
Spent the day at Turn Key Engine Supply working through custom configurations and tunes for the L94 and LC9 engines and testing my new harness.
This new 6.2L/6L80e is going to a lucky D90 owner.
All engines are test run before shipping.
ID:	138910   Click image for larger version
Old January 9th, 2016, 01:34 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Just from curiosity what's the going rate for your turnkey package…
looking for options for '83 LHD 110 SW
Old January 9th, 2016, 01:44 PM
Mostlymonki
Matt
1998 130, 1988 110
Any news on the harnesses Nick? I emailed you a few days back but can see you've been busy (I'm also in need of a couple of other thing from you).
Old January 9th, 2016, 02:21 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
I have built only two custom harnesses so far. Based on the GenIV w/VVT & DoD for the '93/'94 NAS Defender. Plug-n-Play. With the '93/'94,'95,'97 NAS Defenders, '94-'95,'96-'99 Discovery I, '87-'94, '95 RangeRoverClassic, that makes 7 variants alone. Not to mention engine variations, with and without DoD. Plus an ROW version. Way too laborious.
Just invested in Harness CAD software to cad all the appropriate variations and send it off to a harness manufacturer. If you are in a hurry, I suggest you have SpearTech mod your factory harness or get a generic one from them. This "stuff" takes a lot time.
Regarding the pedal bracket. I am placing an order Monday to have them manufactured. Should be able to ship them in three weeks.
Old January 10th, 2016, 07:58 AM
phoenix37's Avatar
phoenix37
john
LR3 LS conversion....and of course why not add nitrous while your at it.
ID:	139021   Click image for larger version
Old January 10th, 2016, 11:11 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Haha - love it! Any link to the build?
Very surprised you don't see a lot of LS swaps into Disco2's. The D2 we had years ago was a great vehicle save for being underpowered.
Any one in NJ that has an LS swap Defender? Will buy lunch for a ride. Not giving my OM617 up anytime soon but very curious how it drives.
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
