GM Gen 4 conversion including LS - Page 50 - Defender Source
Old December 25th, 2015, 02:17 PM
Mostlymonki
Matt
1998 130, 1988 110
happy Christmas everyone! the wife and kids are watching crappy movies, so I'm taking the opportunity to obsess over engine swap problems...
has anyone done a RHD defender with a truck engine yet? only looking at the front of my l92 the alternator is at the same height as the top of the intake - so although Nick's BOM states the accessory relocation bracket is only needed for LHD, I'm not so sure (it cant clear the hood if the TB wont without being reversed).
I've got an ls3 intake manifold to go on, but if I can get away without reversing it and moving the alternator that would suit me much better.... at the moment, I'm thinking of just relocating the idler pulley ($28 part from Dirty Dingo: DD-LS-IRB - Idler Bracket Install LS Conversion LS Swap - DD-LS-IRB - Idler Bracket Install LS Conversion LS Swap) and maybe getting one of these hoods:http://http://www.grpmylandy.com/products/custom-bonnets/landrover-trailer-style-bulge-bonnet.html- I've emailed the company that makes them to ask how far from the front the bulge starts, but if it works then it's save me a fair ammount over moving all accessories and intake around.
Old December 25th, 2015, 03:17 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
It looks like my accessory drive locates the alternator about 3/4" lower.
Old December 25th, 2015, 04:09 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Drew at Goatbuilt.com also makes brackets that may work for you...
Old December 25th, 2015, 06:22 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got them on my LM7, great quality
With those and the car intake you'll clear the bonnet no problem.
Old December 25th, 2015, 07:39 PM
evoblade
Bob
2004 Discovery II
Nick,
Do you have prices anywhere in this post or a website? I'm looking for some information on the kit. Planning on putting a LS motor in my 2004 D2 soonish.
Old December 25th, 2015, 07:50 PM
skitzy's Avatar
skitzy
Nick
91 D90 2.5NA doing LS Gen IV Thing
Originally Posted by skitzy View Post
So would the optimal configuration for this engine upgrade be a 1.003:1 LT230 and those tires?
So if I have a 22D 1.410 ratio LT230, I should get this Ashcroft 1.003 Gear Set?
(Ashcroft Transmissions)
Aschroft says, "This ratio is usually only adviseable for those vehicles with Portal Axles or large diesel engines." Would that include LS Engines too?
Or would it be easier to just ditch the 22D 1.410 ratio LT230, and instead buy and install a Disco 1 V8 1.22:1 ratio LT230?
Here is a survey question: please let us (or PM me) know what LT230 you'd install, or would have installed, or have already installed in a Markiw GM Gen IV LS Defender conversion:
•1.003 ratio
•1.211
•1.222, or
•1.410 ratio
Old December 25th, 2015, 08:03 PM
evoblade
Bob
2004 Discovery II
hmmm, what year D2…only issues with them was 03-04 oil pumps…if it's leaking, fix it. There are MANY D2 with 150k plus on the clock running strong
A LS ins D2 would be interesting, to say the least
D2 had a terrible motor, at least when it went to 4.6 liters. Cracked blocks, slipped liners, oil pump failures, head gaskets, DEXCOOL damage, etc. Take a look around the D2 forums. If they put a good motor in it, 90% of the threads would be about driving the cars and the rest would be three amigos / braking issues.
Old December 25th, 2015, 08:24 PM
Landy_Andy's Avatar
Landy_Andy
Andy
This is an LS specific thread, take the D2 debate elsewhere & don't pollute the thread... That's
Old December 25th, 2015, 09:27 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
OKie Dokie…seems I don't know shit and thanks for enlightening me on the shortcomings of Land Rover motors. Can you please link me to the threads so I can research what I can expect for my D2 motor when it fails. Please go to Dweb and start a thread there, as this is a mainly a Defender site and this isn't the place for discussing the obvious shortcoming from your vast experiences…
I already apologized for polluting this thread with D2 bullshit
Back on topic, I'm planning on running a 1.4 t-case behind my lq4-4l80e buggy…turning 37's
Old December 25th, 2015, 10:03 PM
skitzy's Avatar
skitzy
Nick
Wow! Impressive massive 37 inchers! Thanks for sharing 1.4 transfer case ratio plans mongosd2.
Old December 25th, 2015, 10:08 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
don't be, it's not that impressive…I'm running that t-case on my D2 right now with 37's and believe it or not, a stock 4.0 D2 motor that hasn't self-destructed. Can do 80 all day long, but like with any lifted truck, it's not built for speed...
Old December 25th, 2015, 10:36 PM
defender1844
Amit Likhyani
E-Rod
Originally Posted by nmarkiw View Post
There have been several people asking what engine or package to buy from GM. (new engine)
Currently, GM Performance doesn't offer a suitable engine/trans package for this conversion. They have three different offerings...
Crate Engine
Connect & Cruise
E-ROD
Crate Engine
GM does offer the LC9 (5.3L aluminum) truck engine as a crate option. Part number 19259918. (~$5,000) This can be used on this conversion. Available from Summit, Jegs...
Connect & Cruise
This package comes with a wiring harness, ECM, and optionally a transmission. Problem is GM Performance doesn't off the 6L80e transmission, yet. Therefore, any package engines won't have the correct ECM and wiring harness.
E-ROD
This package is the Connect & Cruise plus down pipes/cats and is California legal. Here again, since the 6L80e is not offered, it has the same problems as Connect & Cruise. Don't wast you money on this one. You will have to scap the down pipes/cat, exhaust manifolds, ECM and harness. Then you are left with the Crate Motor and no CA compliance.
So what are the options? You can purchase the LC9 Crate Motor from GM Performance, a 6L80e trans from the dealer (~$2800), and a wiring harness from the dealer (~$200), and an ECM from Amazon. This won't work in California as a donor VIN is required for an "engine change". I an not sure what other states require.
Will a Car Engine work?
Car engines can be used outside of California. However, the oil pan and pickup, water pump, and possibly the crank pulley will have to be changed. There are three pulley offsets. Close, medium, and long. The truck water pump is required here and uses the long pulley.
Hope this helps.
Let's please revisit the E-ROD solutions for a second. I understand that for the E-ROD ECU to control the transmission you have to buy the 4L85E transmission also from Chevy Performance. I also fully understand that the 4L85e transmission won't work with Nick's adapters. However, Marks4x4 in Australia does make a 4L80e to LT230 adapter. No it's not as good as Nicks. However if it also works for the 4L85e would all 3 of the e-rod engines(LC9, LS3 and even LSA) be options? Could I use the existing cats included in the kit(modified a little bit is OK)?
I definitely want an engine and transmission designed to work together AND I also like the idea of a crate motor rather than rebuilding a 65k to 100k motor out of another truck. The E-ROD idea is compelling especially if it could also be made CA compliant(a nice to have but not essential). I apologize for bringing back a post from page 18 when we are on page 50.
Old December 25th, 2015, 10:48 PM
skitzy's Avatar
skitzy
Nick
Donor 2009 35k miles Sierra 5.3 4WD 6 speed 6L80 ~$2400 US next to Defender 90. Guessing that more of these GM gen IV 4X4 6L80 combos will become available for even less over next few years?
Old December 26th, 2015, 06:29 PM
evoblade
Bob
2004 Discovery II
Sorry for polluting this thread with D2 motor stuff. I'm looking for an LS solution for my Rover motor woes and I believe Nick has exactly what I need. I'll resume watching with interest.
PS. Here is the D2 forum if anyone is interested (where at least two guys are reinventing the wheel regarding chevy motor swaps). Discovery II - Land Rover Forums - Land Rover Enthusiast Forum
PPS. Sorry again and lets get back to replacing the ancient GM design with their latest and greatest.
PPPS. May your combustion gasses all find their way out the tallpipes and not into adjoining cylinders or coolant or the space between the block and the head where there really ought to be some head gasket... Amen!
Old December 26th, 2015, 08:37 PM
Landy_Andy's Avatar
Landy_Andy
Andy
You can also check out LRA 'Les Richmond Automotive' on crack book.... he has some sic vid's of LS's running in RaRo's
Old December 26th, 2015, 09:07 PM
phoenix37's Avatar
phoenix37
john
cool stuff on their page.... interesting claim the LS gets better fuel economy than a TD5.
Old December 26th, 2015, 09:23 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Actually it's not...
Old December 26th, 2015, 09:36 PM
phoenix37's Avatar
phoenix37
john
not interesting or not true? no idea what mpg a TD5 gets...i just know my LS is a hell of a lot more efficient than the 3.5 it replaced.
Old December 26th, 2015, 09:45 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Fwiw, CDN38 mentioned in a thread recently that his td5 flat highway mpg went up considerably. IIRC, something like low twenties to high twenties/low thirties with roamerdrive. So stock td5 might be around 25 hwy. I can't find it, but I found where he said he was doing 85 at 2600 rpm's with roamerdrive.
http://www.defendersource.com/forum/...r-66005-2.html
"Barry is correct!"
Old December 29th, 2015, 11:03 AM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
•1.003 ratio
•1.211
•1.222, or
•1.410 ratio
My original LT230 is a 20D so I believe it is a 1.6. I am going to find a Disco 1 with 1.2 ratio and put that in with the LS3 with 33" tires.
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
