GM Gen 4 conversion including LS - Page 49 - Defender Source
Old December 16th, 2015, 12:47 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
[QUOTE=nmarkiw;697698]Picture of D2 and D1 hi/low shifter housing differences.
D2 is straight, D1/Defender is offset for linkage.[/QUOTE
I changed the front output housings...so they had a center lock, the shifter linkage is part of that
Sorry for the confusion
Old December 16th, 2015, 08:05 AM
35xj
dave rees
63. 88"
Sent a pm regarding price. But does anybody know the total overal length of a 5.3/6l80/230? Trying to cram it into a series project....
Old December 17th, 2015, 06:19 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
Originally Posted by skitzy View Post
Thanks @mongosd2 for clarifying. I went crawling around in the garage and found this Serial Number on an LT230 Transfer Case: 22D168847D. So per your chart it is a 1.410:1.
"22D 1.410 Defender 4 Cyl bar 2.5 Diesel Nat Asp.", per some random googled website.
So this 22D 1.410 ratio LT230 is good-to-go for Nick's Gen IV LS swap?
Thanks.
Your 22D will work, however I think a 1.22 would be a better ratio for the 6 speed at freeway speeds.
Old December 18th, 2015, 03:57 PM
bhautosport
justin mancino
none
Hi, I am new to this forum. Can someone direct me as to how or who I would purchase one of these LS conversion kits from.
thank you
justin
Old December 18th, 2015, 04:03 PM
thank you
justin
Contact Nick. http://www.defendersource.com/forum/...arkiw-318.html
Old December 18th, 2015, 04:40 PM
bhautosport
justin mancino
none
Ok, that's what I figured. I will PM him.
thank you
justin
Old December 19th, 2015, 04:25 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Nick, have you finished the 110 engine harness you were working on? I would be interested in buying one for my 110 lc9 swap.
Old December 19th, 2015, 12:55 PM
Defender110Pilot
1986/Defender 110
Hey Guys,
I currently have the 1.4 LT230, should I have this changed to a 1 or 1.2 for my LS3/6L80E conversion?
Best Regards,
Old December 19th, 2015, 04:24 PM
skitzy's Avatar
skitzy
Nick
91 D90 2.5NA doing LS Gen IV Thing
Originally Posted by nmarkiw View Post
I'm running 1.003:1 LT230, 4.11 gears and 35" tires. The only way you will get any mileage out of these LS engines is to keep the RPMs down at highway speeds. It has plenty of torque. Plus you want an overdrive gear on the highway not a business gear.
With this setup I have plenty of power. On the highway it was in 5th and 6th. 6th on the straights, 5th uphill, 4th to pass. And this is a 5.3L not a 6.2L.
Most cases you will have to jump up a ratio in the LT230.
So would the optimal configuration for this engine upgrade be a 1.003:1 LT230 and those tires?
So if I have a 22D 1.410 ratio LT230, I should get this Ashcroft 1.003 Gear Set?
(Ashcroft Transmissions)
Aschroft says, "This ratio is usually only adviseable for those vehicles with Portal Axles or large diesel engines." Would that include LS Engines too?
Or would it be easier to just ditch the 22D 1.410 ratio LT230, and instead buy and install a Disco 1 V8 1.22:1 ratio LT230?
Old December 19th, 2015, 04:27 PM
Here's my take on the LT230 ratio choice. In a 90, I think its undergeared when powered by a 3.9 using the 1.22 with the ZF box.
It could easily handle the 1.003 ratio, which LR used on the RRC when they added the Chrysler 727 auto transmission.
Old December 20th, 2015, 07:06 AM
kang2222
osamogie ekhaguere
none
hi guys,
new member here, seeking advice on achieving this look and ride height on a tight budget, i want cheaper alternatives to the cooper ltz as they are too expensive, also wouldnt mind using 20" wheels with bigger tires as long as i get the same ride height. what spacers should i use, grill, i know those are terrefirma wide arch fenders.
also any body willing to do a custom interior alcantara and leather should pm me, if you can do this for a decent rate
Old December 20th, 2015, 07:54 AM
BlackField's Avatar
BlackField
Oscar
D110
Originally Posted by kang2222 View Post
hi guys,
Please start a new thread and post pictures of what you have.
Old December 21st, 2015, 01:27 PM
86Defend110
Jesse
The computers are not compatible. Pre-2010 and 2010 on. Also, the years for the ECM & TCM need to match. The TCM can be reflashed with a different OS. The ECM can't.
Will a 2013 6L80 work with the 2010 5.3 I have? I am having a hard time finding a trans at a decent price.
Thanks.
Old December 22nd, 2015, 11:51 PM
defender1844
Amit Likhyani
does anyone have a good source for 6 liter LQ9 with transmission bolted up?
Old December 23rd, 2015, 11:32 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
The LQ9 is a Gen3 and won't work with the 6l80e.
Old December 23rd, 2015, 01:10 PM
phoenix37's Avatar
phoenix37
john
Thanks.
What are you getting quoted? plenty of 2010 6l80s in the $1200-1500 range on Car-part.com
Old December 24th, 2015, 10:50 AM
86Defend110
Jesse
That range would work for me. I called several places around Phoenix and most have a core charge of $200-$350. Cheapest so far was $1750 and highest around $2300. I found a good deal on an 2007 but that won't work with my 2010 ECU. Also found a good deal on a 2013 but I am not sure if that will work with the 2010 ECU.
Old December 24th, 2015, 10:54 AM
phoenix37's Avatar
phoenix37
john
Here is one for $1k...im going to start charging you a finders fee Be sure to confirm its not a 6l90
2010
Transmission
GMC Truck Sierra 1500 A.T., 6.2L, 4x4,6.2L,AUTO TRANS-0MI 112 $1050 Chapin #1 Auto Wrecking USA-AZ(Phoenix) Request_Quote 602-276-3828 Request_Insurance_Quote
Old December 24th, 2015, 11:01 AM
86Defend110
Jesse
[QUOTE=phoenix37;700717]Here is one for $1k...im going to start charging you a finders fee
LMAO! No doubt, you found the motor for me too! Should I send a list of all the other shizz I still need?
Thanks man!
Old December 24th, 2015, 12:32 PM
mattarm's Avatar
mattarm
Matt
1993 D110
*|*American Pick-Up Salvage
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
» Defender Registry
Money Pit
Grover
Baloo
phreeb
Add your Defender
