GM Gen 4 conversion including LS - Page 48 - Defender Source
Old December 10th, 2015, 10:32 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by UL1700 View Post
Two issues, pipe diameter the ls needs 3 inch for MAF and you wouldn't want to choke it and there is not much space for an air box although I'm sure something would fit
Umm.... 4" off the MAF I believe....
I was looking at one of these for a snorkel setup :
Ump 4 Inch Super Air Filter With 8 Inch Extra Long Canister For Engines That Have 250Hp To 300Hp
Or you could use a truck filter like on Rob's ORA Eurofighter....
Name:	ORA Eurofighter.jpg
Old December 12th, 2015, 10:54 AM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
Transfer Case
I don't think I'm going to use my Defender case with the LS because it's 1.4:1 would a locking case from a Disco 2 work for this conversion? Thanks
Old December 12th, 2015, 11:19 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
1.2:1 D1 case will fit. The D2 case has different linkage and front drive flange.
Old December 12th, 2015, 11:36 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Yes, just swap the front driveshaft flange from your existing case and rear output housing for speedo…if it doesn't have CDL, just swap the complete front output housing
------ Follow up post added December 12th, 2015 11:39 AM ------
You can use the D2 case, change the front DS flange from your current case. If the D2 donor case doesn't have the CDL nipple, just swap the front output housing. You'll also need to swap your rear output housing for your speedo.
use your existing linkage...
Old December 12th, 2015, 11:41 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
...and the hi/low shift housing.
Old December 12th, 2015, 11:43 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
huh…it's the same on both cases...
Old December 12th, 2015, 11:45 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
No, different lever configuration. Cable vs linkage.
Old December 12th, 2015, 11:53 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
They swap right in, never had a issue with any of the t-case swaps we've done and I think we are up to 5, 110's, D1's, D2's and D90…
A quick edit on this…I did this on my 110, running a D2 box out a 2001, so it had the CDL, changed the flange on the Front and used the rear output housing for speedo
Did another 110 with a D2 without CDL, swapped the front and rear output housings
Not agruing, just clarifying
Old December 12th, 2015, 12:15 PM
phoenix37's Avatar
phoenix37
john
D2 Lt230...
The locking centre differential was still fitted until early 2001, although the linkage to operate it was not attached, as Land Rover believed that the traction control and newly developed Hill Descent Control would render it redundant. The actual locking mechanism was removed in early 2001, before being fully reinstated (with linkage) with the facelifted 2003 model. Whilst the traction control system worked very effectively, it did not offer the same level of control and smooth operation as the vehicles fitted with the differential lock. Customer demand saw the diff lock controls fully reinstated as a cost option only (standard on top of range HSE/SE vehicles) on UK/Irish models, and aftermarket kits are offered by several vendors for those vehicles which were produced with the lock, but not the linkage.
Old December 12th, 2015, 01:10 PM
86Defend110
Jesse
Thanks for all the great input guys! Sounds like a bit of extra unnecessary work, which I already have enough of! Maybe I'll wait and find a 1.2 D1 case...
Old December 12th, 2015, 07:15 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Picture of D2 and D1 hi/low shifter housing differences.
D2 is straight, D1/Defender is offset for linkage.
ID:	136886   Click image for larger version
Old December 12th, 2015, 10:53 PM
DRDefender
Peter
2002/D90
Hi Nick,
I have been lurking in the thread for a while waiting for a D90. I finally got my hands on a 60th Anniversary this week. I sent you a PM regarding the parts I need from the list you sent me earlier. Do you have the adapters available?
Regards,
Peter
Old December 13th, 2015, 09:52 PM
skitzy's Avatar
skitzy
Nick
91 D90 2.5NA doing LS Gen IV Thing
Recommended LT230 Transfer Case Ratio?
So many Lt230 Transfer case gear ratios. See @Red90 list of LT230 cases here: Land Rover Gear FAQ
Any recommended LT230 Transfer Case ratio for a Defender 90 GM Gen IV LS Swap?
3.32
4.34
1.003
1.222
1.1923
1.211
1.206
1.41
1.667
2.69
Old December 14th, 2015, 01:05 AM
skitzy's Avatar
skitzy
Nick
The Gen IV truck engines fit. LMG, LC9, LY5, LY6, L92, LSA For the defender, the truck intake clears the hood when you turn it 180 degress. The low car intake fits the Discovery. Yes, this fits Discovery 1 and Classics too.
Will this engine and transmission combo work?
2009 GMC Sierra 1500 4WD
VIN: 3GTEK13M59G138579
Odometer: 51033 KM
LH6
Vortec 5300 LH6
6 Spd Transmission
aluminum block?
Old December 14th, 2015, 06:26 AM
phoenix37's Avatar
phoenix37
john
The LH6 will work.. .thats what I have in my truck...not sure about the trans.
Old December 14th, 2015, 03:45 PM
Mostlymonki
Matt
1998 130, 1988 110
the UMP one looks good, I'll have to get the motor in and see where theres space... though i was thinking dual snorkels might work well - T pipe off the TB and send one either way... maybe use 2 smaller defender style filters that way instead and not worry about choking it.
Old December 14th, 2015, 04:08 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
3.32
4.34
1.003
1.222
1.1923
1.211
1.206
1.41
1.667
2.69
You need to look at that page again…your posting gear ratio's for overdrives, maxi drive low range gears and such…
Here's a better list:
There are two different 1.2:1 gear sets, the earlier 1.222:1 gear set has stronger teeth than the later 1.211:1 gear set. The change to smaller, weaker teeth was made in the interest of reducing noise.
1.222:1 set was fitted into 28D and 32D (prefix) LT230's.
The weak 1.211:1 set was fitted into 36D, 37D, 38D, 40D, 41D, 59D, 61D, 62D, 68D, 69D, 70D, 80D, and 90D LT230's.
1.410:1 was fitted to 13D, 22D, 25D, 43D, and 57D LT230's.
1.192:1 was fitted to 27D and 29D LT230's.
Old December 14th, 2015, 10:53 PM
Landy_Andy's Avatar
Landy_Andy
Andy
If you go that route there are good deals on EBay for Donaldson filter housings with 2.5" - 3" outlets, could work out cheaper than the UMP setup if your lucky
Old December 15th, 2015, 12:58 AM
skitzy's Avatar
skitzy
Nick
Thanks @mongosd2 for clarifying. I went crawling around in the garage and found this Serial Number on an LT230 Transfer Case: 22D168847D. So per your chart it is a 1.410:1.
"22D 1.410 Defender 4 Cyl bar 2.5 Diesel Nat Asp.", per some random googled website.
So this 22D 1.410 ratio LT230 is good-to-go for Nick's Gen IV LS swap?
Thanks.
Old December 15th, 2015, 11:57 PM
Landy_Andy's Avatar
Landy_Andy
Andy
The 6 speed is the 6L80E.... as discussed in the first few posts of this thread....
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
