GM Gen 4 conversion including LS - Page 45 - Defender Source
Old October 16th, 2015, 09:35 AM
Cpancho
Francisco
1974 land rover series 3 109
yeap, everything is super tight... I should have some pics but not like a documented swap. I have to look for them in the camera roll.
super happy with the swap people can believe when I go freeways 70mph at 2000 rpm doing 20 miles a gallon.
Old October 16th, 2015, 11:21 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
What ever you got.
Old October 16th, 2015, 11:28 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Planning on driving to the north pole soon? Jk
Saves having to carry jerry cans
Old October 19th, 2015, 05:03 PM
UL1700
James
Defender 50th
I sort of posted this as a question on my build tread (http://www.defendersource.com/forum/...ild-58134.html) but though I'd ask here if anyone had any tips on how / where to fit the GM Fuel Tank pressure sensor into the rear mount plastic defender tank? Many Thanks. James
Old October 19th, 2015, 07:45 PM
Landy_Andy's Avatar
Landy_Andy
Andy
What's it look like, my Gen III doesn't have one...
Old October 20th, 2015, 06:03 AM
UL1700
James
Defender 50th
I don't have a pic of mine but here is a link to one on eBay (NEW Fuel Pump Tank Vapor Vent Evap Pressure Sensor AS302 16238399 | eBay) It is not required for the correct running of the engine but is is needed for California and Australian emissions inspections I'm guessing I just drill a suitable sized hole in the top of the tank a push it in but I would like to know first! I'm also pondering weather I could fit it to the first vapor canister mounted on the defender chassis rail. Really as long as its not throwing fault codes or leaking fuel then neither I or I suspect my engineer could really give a s**t
Old October 21st, 2015, 01:11 AM
Landy_Andy's Avatar
Landy_Andy
Andy
I'd try it in the canister first, doesn't look that it'll be that fuel tight if it's just a push fit into a hole in the tank.
Old October 21st, 2015, 07:32 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
My understanding is that the tanks that work with that sensor have a raised portion (air space) that remains above the fuel level. I do not believe the sensor is made to be submerged in the fuel as it has more to do with vapor. My plan is to insert a metal tube in the rubber filler neck and put it there. I am far from knowledgeable but that is the idea I could come up with and the emissions guy agreed that it would be acceptable for the purpose of the inspection.
Fwiw Nick is in Cali and would be the best person to answer since he has first hand experience dealing with the emissions people in Cali
Old October 21st, 2015, 07:50 AM
diamonda
Andrew Diamond
1985 V8 90
Any issues with this conversion in a RHD?
Old October 21st, 2015, 11:49 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
See picture of Fuel Tank Pressure Sensor, Canister, and Vent Valve. All approved by California.
ID:	132914   Click image for larger version
Old October 22nd, 2015, 09:02 AM
Sounder83
Corey Lipham
02 discovery
Smile
Just joined because I want to follow and stay updated on any information regarding the discovery conversion. Great work here everyone... Fascinating.
Old October 23rd, 2015, 05:17 AM
UL1700
James
Defender 50th
Slightly different puzzles but perfectly possible... see my 50th build!
Thanks for the info Nick, I think mounting it in the first canister thing that my 50th has on the chassis rail should fit the bill. The sensor will not see fuel but will read tank pressure... I will have a play and update my build thread with the results
Old October 23rd, 2015, 05:18 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
More adapters getting ready to ship.
Old October 23rd, 2015, 06:49 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
The longer (and better) this thread becomes, the more it makes me want to spend a bunch of $$$.
I have the 6.2 in my pickup and couldnt imagine it in a 90.
Old October 24th, 2015, 04:20 AM
dickyjoe
Richard Lane
1958 Series 2 SWB
Gee the way this is going you might end up with a business selling Land Rover conversion kits!!
Old October 26th, 2015, 10:15 AM
ersatzknarf's Avatar
ersatzknarf
Frank
'96 hybrid
That's beauuuutiful
__________________________________________________
shoefnik wrote: "Itís funny how that moral line you draw for modifying your Rover changes as your needs change."
Old October 26th, 2015, 10:18 AM
Jwillia's Avatar
Jwillia
Justin
87 ROW build in progress
I think I may need the heavy duty one after all Click image for larger version
Old October 26th, 2015, 12:01 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Originally Posted by Jwillia View Post
I think I may need the heavy duty one after all Attachment 133147
The 300M shafts are out of stock. Just placed and order for three more. I will have one available for you in a few weeks.
Old October 26th, 2015, 12:13 PM
Jwillia's Avatar
Jwillia
Justin
Good I will just sell the other setup I got from you with the drivetrain I originally bought.
Old October 26th, 2015, 08:02 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Are they a direct replacement for the one you sent me ?
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
