GM Gen 4 conversion including LS - Page 43 - Defender Source
Old July 21st, 2015, 02:13 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by Roadsiderob View Post
Nick,
i don't think those will work for me. They look like they will add too much length. The injectors aren't too long, they are too small of an OD to fit tightly into the manifold.
Head over to LS1Tech.com - GM LS Performance Forum you should be able to search for the info you need there....
However after a bit of googling, the manifold is an LS3 and it looks like you need the short injectors.....
Name:	LS Injectors.jpg
Old July 23rd, 2015, 03:55 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Out of adapters, again. That makes 35 so far.
Old July 23rd, 2015, 04:04 PM
phoenix37's Avatar
phoenix37
john
Thats great news... well done Nick. How many on the road right now? This thread needs more pics of finished trucks..
Old July 25th, 2015, 01:53 AM
Blackcat
Rob
1989 90
Hello, great to see a 6l80 lt230 kit, could I ask for a cost please?
Old August 9th, 2015, 10:04 AM
You guys are not alone. Saw this today:
ID:	126824   Click image for larger version
Originally Posted by pendy
I'm here for the D's
Old August 9th, 2015, 06:01 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Lokar throttle pedal (APP) adapter for Defender.
ID:	126844   Click image for larger version
Old August 10th, 2015, 03:52 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Very nice Mark, it's all the little parts that take the time to develop & alot of the cost but there what make a good kit a great one...
Keep the pic's coming... always looking for more ideas to borrow
Old August 13th, 2015, 04:03 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Added some pic's & drive shaft thoughts to the Gen III thread here - http://www.defendersource.com/forum/...i-52933-8.html
Old August 26th, 2015, 10:22 PM
skitzy's Avatar
skitzy
Nick
91 D90 2.5NA doing LS Gen IV Thing
When will you be making a new batch of LS adapters and offering them again?
Hi Nick,
Found an engine with 6 speed transmission combo on this 2010 4wd Tahoe.
Vehicle Options and Features: Specifications
  • Year:
    2010
  • Make:
    Chevrolet
  • Model:
    Tahoe
  • Trim:
    LS 4WD
  • Body Style:
    SPORT UTILITY 4-DR
  • Engine Type:
    5.3L V8 OHV 16V FFV
  • Transmission:
    6-Speed Automatic
  • Drive Line:
    4WD
  • Brake Type:
    All Disc
  • VIN/Serial Number:
    1GNUKAE04AR226217
  • Odometer:
    164347 KM
Thanks.
Old August 27th, 2015, 06:39 PM
gavin.'s Avatar
gavin.
Gav
V8 County Ninety
Please put my name down for the next batch of adapters. I have just found a solution to my California conundrum. PM sent.
Old August 29th, 2015, 06:18 PM
UL1700
James
Defender 50th
Hi, does anyone have a part number for the evap system pressure sensor as I could not find it on the BOM but I could be going blind ?
Many thanks
James
Old August 29th, 2015, 06:24 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Many thanks
James
Fuel Tank Pressure Sensor
13502903
------ Follow up post added August 29th, 2015 03:25 PM ------
Originally Posted by skitzy View Post
Hi Nick,
  • Year:
    2010
  • Make:
    Chevrolet
  • Model:
    Tahoe
  • Trim:
    LS 4WD
  • Body Style:
    SPORT UTILITY 4-DR
  • Engine Type:
    5.3L V8 OHV 16V FFV
  • Transmission:
    6-Speed Automatic
  • Drive Line:
    4WD
  • Brake Type:
    All Disc
    1GNUKAE04AR226217
  • Odometer:
    164347 KM
Thanks.
I have another batch in the work. (qty 15) Should be about 5 weeks.
Nick
Old August 29th, 2015, 10:34 PM
skitzy's Avatar
skitzy
Nick
OK thanks Nick. Please reserve one for me. PM sent.
Old August 30th, 2015, 08:37 AM
djm's Avatar
djm
dwayne
1993 defender 110
I sent you a message Nick but haven't gotten a reply yet please put me down for one too!
Old September 3rd, 2015, 03:28 AM
Kitsan
Kit
2012 110
I came across your big conversion thread while looking for options on my 1997 manual 3.9 V8.
I live in Dubai but we have most of the GM engines over here and there are two good workshops I know of that could do the work.
So, what can you do for me?
Ideally I would like the easiest/cheapest option as i'm not too worried about massive power, anything around 200hp would be amazing, but I definitely need A/C!
Many thanks,
-Kit
Old September 3rd, 2015, 12:17 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Many thanks,
-Kit
I'd suggets you go back to the first post & read the complete thread, work out what you want & go from there.
Old September 5th, 2015, 02:34 PM
Kitsan
Kit
2012 110
I have read through most of it but there isn't a price list for the engine/gearbox mounts...etc?
In my market the L76 from a Commodore/Pontiac G8 has a 6L80E and is the cheapest part car, is this suitable as nmarkiw only lists LMG, LC9, LY5, LY6, L92, LSA on page 2?
If that L76 isn't suitable then the smaller LC9 is my next best option from a 1500 Silverado.
Has anyone had stock items fail because of the increased torque?
Old September 5th, 2015, 02:42 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
The car engines are not listed because the truck (Vortec) engine fits. You have to change several parts on the car engine to make it fit. Oil pan, intake manifold, fuel rail, injectors, crank pulley.
Also, the car transmission (6L80e) has to be converted. Sump and filter changed to deep truck style. Output shaft is wrong. Some output shafts can be cut off. Then the tail housing has to be converted to dry by installing the shaft seal and plugging the holes in the case.
Far easier to start with a 4wd truck engine/trans. I will send you pricing.
I have two customers installing LSA engines in Defenders (Supercharged 6.2L, 580HP). I supplied them with 300M adapter shafts. The LT230 will probably hold up. The axles/diffs will have to upgraded. A standard 6.2L (408HP) should be fine with upgraded diffs and drive lines.
Old September 5th, 2015, 02:58 PM
Landy_Andy's Avatar
Landy_Andy
Andy
If your looking for low cost, find a wrecked Silverado with the LM7 iron block, or just pick one up from a local pick-a-part.... Stuff a cam in it and you'll have a solid 300bhp and plenty of torque to turn the stock half shafts into twisted ornaments
Check out my budget(ish) LM7 engine swap here : http://www.defendersource.com/forum/...-ls-51290.html
Old September 5th, 2015, 03:00 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
LM7 is a GenIII. Won't work with the 6L80e.
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
