GM Gen 4 conversion including LS - Page 42 - Defender Source
Old June 27th, 2015, 01:32 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by nmarkiw View Post
Just picked up 2000 D2 for conversion R&D.
If only I'd waited and not built up a 4.6 for mine....
Old June 28th, 2015, 05:25 AM
UL1700
James
Defender 50th
First the D2 next the p38
Old June 30th, 2015, 01:56 PM
Mostlymonki
Matt
1998 130, 1988 110
any pics of the shifter arrangement inside the cab? I'd be doing it on a manual, and those auto consoles are impossible to get hold of over here so was thinking along the limed of the lokar shifter that bolts onto the trans case.... if it left the lever in the right place of course.
------ Follow up post added June 30th, 2015 06:59 PM ------
Radiator, Y-pipe, Lokar upper cable bracket.
think you'd get full articulation on the front axle without the prop fouling something? looks really close to both the trans and the y pipe in that pic.
Old June 30th, 2015, 02:13 PM
Originally Posted by Mostlymonki View Post
...and those auto consoles are impossible to get hold of over here....
Ashcroft Transmissions
Old July 6th, 2015, 11:44 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
This installation has a Toyota 3rd member. It's a lot closer than the LR 3rd member. We will see what happens when I articulate it.
Old July 6th, 2015, 11:47 PM
TMWTP's Avatar
TMWTP
Jon
1989 One Ten
The new gauge cluster arrived.
Any pics of the cluster installed?
'14 F250 dd tow rig
'17 Discovery (wife's dd)
'88 110 under the knife
'12 Rockware 3-seat rock buggy - FOR SALE!
'13 LR4 - FOR SALE!
'83 110 - FOR SALE!
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
D110 6.2L project Day (I don't know)
Shifters.
Lokar 8" cable shifter, 12" with out center cluster.
ID:	124497   Click image for larger version
ID:	124499   Click image for larger version
Old July 6th, 2015, 11:53 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
I haven't gotten to it yet. I did plug it into the ODBII port. Immediately displayed gear selection, trans temp, check engine light, oil pressure... It's very nice. Trying to get this 110 done so I can get back to my rig.
Old July 7th, 2015, 05:50 AM
Shifters. Lokar 8" cable shifter, 12" with out center cluster.
That's the way LR should have done auto Defenders in the first place
Old July 7th, 2015, 12:15 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
I have these Lokar installation kits for the ZF also.
Old July 7th, 2015, 02:41 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
What ac condenser is the 110 running? is that a gm compressor? Also what trans cooler is that? Thanks
Old July 7th, 2015, 02:53 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Rovers North under dash A/C system.
Sanden compressor. Found on most Defenders. (except '97 NAS) Just changed the pulley/clutch.
The cooler is a PermaCool 1022 w/-6 fittings.
Old July 17th, 2015, 07:53 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Heads up... Les Richmond Auto in Aus has just started a LS D2 conversion also... Interesting to see how that goes, there suggesting it'll be using std instrument cluster.... Keep an eye on their FB page for updates.
Old July 17th, 2015, 08:57 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Made some progress this week on Recon Rovers D1 6.2L install. This truck has Toyota 3rds. The reinforcing rib on the oil pan looks like it will foul the diff. I expect I have some grinding to do. There is a half inch clearance between the PS pump and the steering box. The alternator is in light contact with the hood reinforcement. I expect the hood reinforcement will get an "adjustment" of some type. So far all the hardware has gone in nicely. I'm using a bare LT230 case at the moment as I have a 1.003:1 LT230 under construction for this car, but it's not ready yet. The engine was installed first and the transmission and transfercase were put in from the bottom on a transmission jack. The engine balances well and the gearboxes can be removed for service without any unusual difficulty. The truck is running 35" tires with 4.56:1 diff gears. I'm expecting to have to swap in some 4:11 third members, as I expect it will be geared too low. I intend to try and rework the wiring harnass myself instead of sending it out. The 6.2 is out of a 2013 Silverado pickup (I think). The intake manifold that I was supplied is GM P/N 12602477. It is set up for the same MAP sensor as the truck intake and also uses the short injectors. The injectors from the pickup are the right length, but they are too small a diameter and are a loose fit in the intake....so I'm about to get an education on GM fuel injectors.
ID:	125326   Click image for larger version
ID:	125328   Click image for larger version
ID:	125330   Click image for larger version
ID:	125332   Click image for larger version
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old July 18th, 2015, 11:39 AM
reconrover
Pat G
97 and 2002 Disco's
The Zombie crusher
Hey Rob, thanks for the pics, can't wait to see how things progress. Great to see the motor in the beast!
Old July 18th, 2015, 06:19 PM
i remember that truck! i thought the exocage was pretty awesome...glad to see it getting a new lease on life!
Old July 20th, 2015, 07:34 PM
Metcalf
Brennan Metcalf
none
I stumbled upon this thread doing some research while looking for an adapter for a 6l80 to lt230. I tried sending a PM about purchasing an adapter but it looks like new members have reduced options....
Could you please send me a PM about how to go about purchasing one of your adapter packages. It looks like exactly what I need for a project I have coming up.
Thank you.
Old July 20th, 2015, 07:45 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I got all the info I needed to rework my harness from Brenan, here Vortec 4.8/5.3/6.0 Wiring Harness Info and on his FB page also. Hope that helps....
Old July 21st, 2015, 12:53 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Rob,
Just use the FAST injector extensions. 146025
Old July 21st, 2015, 01:06 PM
Roadsiderob
Robert Dassler
1994 D90
Nick,
i don't think those will work for me. They look like they will add too much length. The injectors aren't too long, they are too small of an OD to fit tightly into the manifold.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
