GM Gen 4 conversion including LS - Page 41 - Defender Source
Old June 8th, 2015, 10:50 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Nick, I noticed the return port on the steering box is capped off, are you using the bleed as a return to the pump ?
Old June 8th, 2015, 10:53 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Just haven't gotten to it yet.
Old June 8th, 2015, 11:29 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Argh... Ok, did you see the Parker adaptor I posted for the return tube ? Got mine last week, fits nice & tight up to the rubber tube stop once the bubble flare is zipped off
Old June 9th, 2015, 06:40 PM
PM Nick for the kit parts.... you can make it as cheap as you want after that, plenty of iron block 5.3's in the salvage yards....
I already did that. I know how much to expect for the project cost. In my opinion it's totally worth it and I have spent easily that much on other conversions trying to make Land Rovers go fast. I'm just saying, that is a reason. Not everyone has the coin to do the swap when a RV8 can be done on the cheap. But just to be clear...I still want one!
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 12th, 2015, 10:12 PM
UL1700
James
Defender 50th
Has anyone come up with an alternate to the Lokar pedal? At $350 for the modual and $92 for the peddle (Summit prices), it has become a rather expensive purchase!
James
Old June 12th, 2015, 10:21 PM
mattarm's Avatar
mattarm
Matt
1993 D110
I am pretty sure that John worked up a solution with the stock pedal.
Old June 12th, 2015, 10:29 PM
phoenix37's Avatar
phoenix37
john
I used the stock pedal and bolted the truck pedal that came with the motor to the outside of the bulkhead. Ran the throttle cable through the LS pedal arm so that the cable would depress the LS pedal when you stepped on the stock pedal. this was a rough mock up before i trimmed the cable and added washer etc. Ultimately i abandoned this set up and bit the bullet and bought the lokar. there was just not enough travel for me to feel safe. felt like almost instant WOT. Im sure there is a version of this that could work but didnt experiment further with it.
Old June 12th, 2015, 10:48 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Couldn't find an ECU mount I liked so modelled this one up, it'll have a dual module MTA fuse box mounted onto the top back of it and be in 16g MS. Should work nice mounted to the bulkhead in the old heater location.
Name:	ECU Mount.jpg
Old June 12th, 2015, 10:52 PM
UL1700
James
Defender 50th
Thanks for the tip, Unfortunately I don't think it would get through engineering over here and I like control An old 101 I had, had a bad SU carb setup on it and it was a little tricky (WOT or Nothing). I see the Corvette pedal advertised but I don't particularly want to import one and find that it is as impossible to retro fit as the Holden Pedal I have!
James
Old June 17th, 2015, 10:31 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Wot.... no more pictures..... I'm getting withdrawl symptoms !
Old June 18th, 2015, 10:27 AM
ersatzknarf's Avatar
ersatzknarf
Frank
'96 hybrid
Agreed ! ! ! I love this thread
__________________________________________________
shoefnik wrote: "Itís funny how that moral line you draw for modifying your Rover changes as your needs change."
Old June 19th, 2015, 09:16 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Finished most of the rework on the 5.3 harness with a nice new fuse box. Just to add the dash gauge sensor wires & it'll be done ready for looming up.
Old June 19th, 2015, 09:29 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Nice!
Are those WeatherPack connectors?
Old June 19th, 2015, 09:53 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by don View Post
Nice!
Similar, Delphi Metri-Pack 150 series, same as GM use on the engine loom. I figured if they've been used for OEM & lasted this long they must be decent. No signs of corrosion in any of them.... I guess time will tell !
http://motorsportswiring.com/metripa..._44_45_46.html
New wires are all TXL from there too. I'll be making a complete new vehicle loom next as the old one was in poor condition and there are quite a few new wires to be added for all the extras. That'll be in TXL as well but due to the limited number of colors available in 16g I'll be using these colored heat shrink idents at each end to mimic the OEM solid & trace.
http://www.ebay.co.uk/itm/2611376552...%3AMEBIDX%3AIT
Old June 21st, 2015, 10:08 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
D110 6.2L project Day 7
Radiator, Y-pipe, Lokar upper cable bracket.
ID:	123317   Click image for larger version
ID:	123319   Click image for larger version
ID:	123321   Click image for larger version
Old June 21st, 2015, 10:16 PM
Departing90
Sasha
95 D90
May I ask where you sourced tye aluminum radiator?
Thank u
Old June 21st, 2015, 10:38 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Thank u
I have them custom built with Spal fans. One for the Defender and one for the RRC/D1.
They come with 1-3/8" upper and 1-1/2" lower specifically for the LS conversion. 11" fans on the Defender radiator, 12" on the RRC/D1.
Old June 21st, 2015, 10:52 PM
Departing90
Sasha
95 D90
Thank you
Old June 21st, 2015, 11:08 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Thanks Nick.... After a crap week at work.... A dose of LS pic's is most welcome !
Old June 27th, 2015, 12:24 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Just picked up 2000 D2 for conversion R&D.
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
