GM Gen 4 conversion including LS - Page 40 - Defender Source
Old June 5th, 2015, 12:32 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
D110 6.2L project Day 4
Fuel Pump
Yes, we had to drop the tank to install the high pressure pump.
ID:	122311   Click image for larger version
ID:	122313   Click image for larger version
ID:	122315   Click image for larger version
ID:	122317   Click image for larger version
Old June 5th, 2015, 10:02 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by nmarkiw View Post
Fuel Pump
Hi Nick,
What's the part number on the pump.... I'll need a couple of them for my tanks.
Old June 5th, 2015, 12:19 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Originally Posted by Landy_Andy View Post
Hi Nick,
Walbro pump F20000141
wiring pigtail 94-615
Old June 5th, 2015, 02:24 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Old June 5th, 2015, 03:39 PM
mattarm's Avatar
mattarm
Matt
1993 D110
I have this pump, never used as I went a different direction. Will let it go cheap along with extra bits laying around.
Old June 5th, 2015, 07:18 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
D110 6.2L project Day 5
Intake manifold and accessory brackets.
ID:	122367   Click image for larger version
ID:	122369   Click image for larger version
ID:	122371   Click image for larger version
ID:	122373   Click image for larger version
ID:	122375   Click image for larger version
ID:	122377   Click image for larger version
Old June 5th, 2015, 07:53 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Holy Mother of Pearl, that is sweet looking.
Old June 5th, 2015, 08:21 PM
Landy_Andy's Avatar
Landy_Andy
Andy
That's looking very slick... well done !
Old June 6th, 2015, 05:57 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Hi Nick,
Nick,
Are you keeping the OE pipes or upgrading ?
I need to install all new so was thinking of using -6 through out.... just not sure on the Pollak dual tank valve, it's only spec'd to 65psi....thoughts ?
I could just swap out one tank to the new HP pump & have the other LP pump act as a transfer into the main one via the fuel return port, not as 'seamless' as the dual tank valve but does simplify things a bit from the pipework point. Would prob need a a one way valve in the LP feed to stop the 'Aux' tank being back fedd with the return line fuel.
Old June 6th, 2015, 06:03 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Nick,
I have been using the stock lines. Except from the Corvette fuel filter to the fuel rail. There I use a -6 braided hose.
Old June 6th, 2015, 06:05 PM
phoenix37's Avatar
phoenix37
john
I can tell you from painful experience you want to make sure your fittings are well over the max psi...i don't think there is a single fitting or line on my fuel system now that can't handle 200psi plus.
Andy call these guys and tell them what you need. amazing quality stuff.
http://www.purechoicemotorsports.com/index.cfm
Old June 6th, 2015, 06:06 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Umm... just not sure if the Pollak valve will be up to it.... gonna have to think about that one.
------ Follow up post added June 6th, 2015 03:09 PM ------
That's one of my fears with the dual tank valve, it was never designed to work with the modern HP fuel systems. With the main & aux tank setup the HP lines would all be -6 & AN fittings. For the small extra cost the transfer line will be too, a Summit -6 check valve is only $46.
Old June 6th, 2015, 06:13 PM
phoenix37's Avatar
phoenix37
john
A failed summit fitting torched me and almost burnt my house down... don't buy that crap.. call the guys from the link above. google and you will find countless burnt cars and trucks due to bad fittings.
Old June 6th, 2015, 06:15 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Earl's it is then
http://www.summitracing.com/int/part...6erl/overview/
All the hose & fitting I'd planned to use were Earl's anyway... might as well keep it looking the same quality.
Old June 6th, 2015, 09:11 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
D110 6.2L project Day 6
Trans cooler, exhaust manifolds, coils, drive belt.
ID:	122442   Click image for larger version
ID:	122444   Click image for larger version
ID:	122446   Click image for larger version
Old June 7th, 2015, 11:45 PM
Landy_Andy's Avatar
Landy_Andy
Andy
That looks very 'factory', I can't see why anyone would want to bother rebuilding a dead 3.9 or 4.0 with this option now available. Even using a junk yard 5.3 you end up with so much more power & torque.... Makes it a no-brainer really
Old June 8th, 2015, 09:29 AM
phoenix37's Avatar
phoenix37
john
Fear of the unknown! I bought a D1 to do a 3.9 drivetrain swap for my 3.5. What a huge waste of time and money that would of been. Couldn't be happier with the drivability of this swap.. Just ticked over a 1000 miles on my conversion and it still makes me smile every time i turn the key.
Old June 8th, 2015, 11:56 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Agree - that GM looks "right" in the engine bay of a Defender.
And to add to what Phoenix said - parts for these are available at any chain store. Although not sure what you will need - the 5.3 in the Suburban has only been using filters.
Old June 8th, 2015, 12:59 PM
Cost?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 8th, 2015, 08:42 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by Ren Ching View Post
Cost?
PM Nick for the kit parts.... you can make it as cheap as you want after that, plenty of iron block 5.3's in the salvage yards....
------ Follow up post added June 8th, 2015 05:47 PM ------
That's what I've been trying to do with mine, keep as simple as possible.... hence the NV4500. I'd deff recommend the rocker trunion upgrade if you start with a used motor, cheap insurance
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
