GM Gen 4 conversion including LS - Page 4 - Defender Source
Old January 29th, 2014, 09:01 AM
atlcruiser
david
many
Nice work
We do this basic same thing often in Cruisers. None of it is all that difficult it is just expensive. We spent some time measuring Cruiser vs Rover to see about dropping a 300 tdi into a cruiser, the distances are very close.
The key is the TC adaptor. I think a TLC late model case would work great on the back of a 4L60E dumped into a Defender. Size and output is about right.
Terrence Anderson
Shipping Manager
URBAN LAND CRUISERS LLC
+44 404 915 1281
Atlanta, GA USA
URBAN LAND CRUISERS + ROVERS LTD
1st Floor, 2, Woodberry Grove
London
N12 0DR
UNITED KINGDOM
+44 020 8133 1557
Company Registration No. 09003009
Our new Vehicle Sales site:
Old January 29th, 2014, 09:13 AM
Viggen's Avatar
Viggen
Jarrod
none
Why?
Old January 30th, 2014, 12:41 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Need more details!!!
Old January 30th, 2014, 09:24 AM
mattwhite
Matt White
94 D-90
Nice work
I think it will be the other way around. People will want to dump this setup into their cruiser. Besides the fact the lt230 has thicker gears than an atlas, the cruiser transfer case low range is like 2.5 and the lt230 is 3.3. Yes, you can get lower gears (3.1 I think) for $$$, or you can pull great condition lt230s for $250 all day long.
Old January 30th, 2014, 09:53 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Accessory Brackets
Ok, I will continue to post more updates.
Pictures of the accessory drive. Utilizing the GM P pump and alternator.
No modifications to the steering box.
ID:	88844   Click image for larger version
Old January 30th, 2014, 12:58 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Okay, I'm an LS ignoramus.
The old 265-400 motors I can tell you all about but not these newfangled thingamajigs
Which version of an LS? is that?
I would imagine that an all alloy truck motor might be a good bet, but I just don't really know.
edit...and I presume the AC compressor fits on there near where it sits on the '97 too, eh?
Keith
Old January 30th, 2014, 01:18 PM
http://en.wikipedia.org/wiki/General...0.93current.29
Old January 30th, 2014, 01:20 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Keith
This is a 2012 LMG (5.3L, cast iron block, aluminum heads, truck motor) from a Yukon. It has variable valve timing and displacement on demand. 320HP The LC9 would be the aluminum version of this truck motor.
I didn't use the GM A/C compressor. I made brackets that work with the stock Sanden compressor. Just changed the pulley to serpentine. So you can go with stock A/C, no A/C, or use the GM A/C compressor. (GM compressor mounts down low on the passenger side of the block and uses a separate belt)
I will post a picture of the A/C bracket tonight.
Old January 30th, 2014, 01:23 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
x2 I am not familiar with any LS engines. Do any of the LS engines able to utilize the existing R380 manual transmission, LT230 transfer case, steering components, cooling, charging, intake, ignition, driveshafts etc etc etc from a NAS Defender? All I want is an engine upgrade/conversion.
Old January 30th, 2014, 02:58 PM
UnfrozenCaveman
Keith Armstrong
Various
Thanks Nick,
I'm noodling on this for my '97 so it's already serpentine.
I'll have to start keeping an eye out for the LMG / LC9 locally.
I presume we want the 4wd version of the 6L80E, yes?
...off to google the weight difference
Old January 30th, 2014, 03:15 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Thanks Nick,
Right, it has to be the 4x4 6L80E transmission. The 6L90E won't work.
There are 6.0L (~358 HP) and 6.2L (408 HP) engine choices too.
Old January 30th, 2014, 03:20 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Any sort of luck getting these to be OBD2 compliant, IE not throwing a code in my D2?
Old January 30th, 2014, 03:41 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
You had to open that can of worms.
While this fits in the D1, Defender, and Classic, the wiring in the D2 is more of a challenge. The D2 has a BCM like the P38's BECM. (Body Control Module) I need to sit down and work out the minimal interfacing required.
As far as OBDII, this uses the GM ECU and TCU with its' own OBDII connector. Easy for the Defender as the 14CUX/GEMS is removed with modularity.
I am not sure if I will have to interface the CAN busses between the D2 BCM and GM ECU yet. But that can be done with a programmable CAN bus router. Not ready to go there just yet.
Regarding throwing codes. You can disable what you don't need in the GM ECU/TCU.
We are still working out the CARB issues of the "engine change" in California. Although, I am using Magnaflow 50 state legal cats. You guys will be the first to know when I get it past the DMV referee.
Old January 30th, 2014, 03:56 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I appreciate the response! The last thing I want to do is throw another Rover V8 in my disco.
Old January 30th, 2014, 05:32 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Basically everthing forward of the transfer case gets replaced. You keep the LT230, drivelines and transfercase mounts. The LR steering box stays with the addition of the GM steering pump. The current conversion only supports the 6L80E auto box. As one of the others pointed out, the NV4500 might fit. (if you wanted to stay manual gear box) That still has to be tested. Also, the Y-pipe gets replaced. You would be able to keep your cat-back.
Old January 30th, 2014, 05:42 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Old January 30th, 2014, 06:13 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
While this fits in the D1, Defender, and Classic, .................................................. .................................................. .................................................. ..............................................
Mmmmmmmmm, I stopped reading after Classic...
Phillip, who's going to have the first LS Hunter?
Rent my
Old January 30th, 2014, 08:18 PM
exmod110's Avatar
exmod110
Don Lang
ok, NICE set up!!!!!
What about in a RHD unit??????? that had a 300tdi,HMMMMMM????
85 exmod 110 rhd 300tdi
Old January 30th, 2014, 10:00 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
A/C Brackets
Factory Sanden compressor.
ID:	88893   Click image for larger version
Old January 30th, 2014, 10:07 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Out with the old, in with the new.
ID:	88895   Click image for larger version
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
