GM Gen 4 conversion including LS - Page 38 - Defender Source
Old May 4th, 2015, 06:31 PM
phoenix37's Avatar
phoenix37
john
isn't the output shaft on the 6l80 the same regardless of 2wd or 4wd applications?
Old May 4th, 2015, 06:59 PM
UL1700
James
Defender 50th
No but 2wd to 4wd can be done! It's described in detail in my build thread!
Old May 4th, 2015, 10:23 PM
SGS714's Avatar
SGS714
Scott Striglos
3xRRC 2xD90 2xD110 Series II, IIA
Originally Posted by nmarkiw View Post
The Walker Quiet-Flow 21047 is a great muffler for this conversion. Same length as the stock muffler, quiet except when you get on it. Then it growls. Just enough attitude, won't drive you crazy. Stainless.
Original application, Dodge RAM 1500 with a Hemi.
Amazon.com: Walker 21047 Quiet-Flow Stainless Steel Muffler: Automotive
This is a 2" muffler, forgot I had a 2.5" Magnaflow System.
Thank you,
67 Series II
71 Series IIa 88" ACR 2.8 Power Plus
89 RRC 2 door VM 2.5TD
93 D110 NAS #327
94 2x D90 NAS #'s 1076 ACR 4.8, 1161 SBC
94 D90 NAS now a D110 HS 2.8 aka Project Wolf
95 2x RRC
1-SWB,Doing the LS Gen IV 98% Done
1-LWB 300tdi
Old May 4th, 2015, 10:34 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
No, that's not correct. 2.5" inlet, 2.5" outlet. I have a 2.5" Magnaflow system. Went right in.
------ Follow up post added May 4th, 2015 07:40 PM ------
No they aren't. Still in the "work in progress category"
Scott,
I thought we sorted all that out with Gary. Tach, speedo, and MAP. What issues are still outstanding? You should be running E38_0011.ctz tune file.
Old May 4th, 2015, 11:14 PM
SGS714's Avatar
SGS714
Scott Striglos
Scott,
Maybe I'm mistaken on the exhaust size. Will check out in the morning....He's getting my daughters car back in service. Yes V11 is what we are running; MAP is sorted out but the RPM or MPH's still aren't reading correctly.
------ Follow up post added May 4th, 2015 10:19 PM ------
Anyone waiting for a low mile engine ought to consider this one. I have no dog in the fight just passing along info. I bought mine from this guy and ship was very reasonable. Ending price wont be much more than the starting price.
2013 Chevrolet 5 3 LC9 Vortec Engine and 4x4 6L80E Transmission Camaro Nova | eBay
Thank you,
67 Series II
93 D110 NAS #327
95 2x RRC
1-LWB 300tdi
Old May 5th, 2015, 05:04 AM
djm's Avatar
djm
dwayne
1993 defender 110
Originally Posted by UL1700 View Post
Hi, one of them is me (in vic) my build thread is here http://www.defendersource.com/forum/...ild-58134.html It has sat idle for a while due to other commitments but I have just started picking up the pieces again (monster rad now installed and wright up to follow) I will PM you my phone number if you want. If you don't want the go with the 6l80 I have a bell housing to mate the LS engines to the ZF 4 speed, was about to list it on ebay!
ah excellent! just had a breeze through your thread that answers some of my concerns great write up cheers! i will be referring to this a bit i think! now i have a work vehicle im currently in the stages of hoarding all the bits i need to do the job so not planning on stripping my 110 just yet so i can keep taking it out on the weekends when time allows, but once i do i will most definitely get in contact with you! thanks for the offer on the zf housing but now im confident its not much of an issue to get our 2wd 6l80e to work that's definitely the path i want to take.
Old May 5th, 2015, 05:11 AM
djm's Avatar
djm
dwayne
1993 defender 110
where did you source your 4wd 6l80e housing? im guessing us wrecker not aus?
Old May 5th, 2015, 03:43 PM
bansheeboyo
scott
defender 90 300 tdi
So what all included in the kit ?
what sort of price am i looking at ?
Old May 6th, 2015, 06:50 AM
UL1700
James
Defender 50th
Almost all of the parts other then engine and box have come from the US. Summit are great with overseas delivery and Mark was a fantastic help. Unfortunately recent currency fluctuations have made US parts about 20% more expensive then when I started if you keep your orders under 1000 AUD it's still often worth it though.!
Old May 7th, 2015, 06:53 PM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
a while back someone else asked this but I couldn't find the answer again and there might be some change.
What is needed for this to work in a 2003 2004 D2? And say that D2 was not in California.
Old May 7th, 2015, 07:27 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Mechanically it's not that dissimilar to installing onto a classic or D1, area of work that needs to be done is the integration of the engine ECU and the D2's BCM. Unless that is, Nick's already got that in hand.... prob not that hard for someone who's worked with CANBus.
Old May 8th, 2015, 02:55 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
The engine mounts are different. Then there is the 4.0L vs 4.6L differences. The 4.6L came with the ZF4HP24 which is longer than the ZF4HP22. The front drive line is a different length. I have to figure out where they moved things like the transfer case weldments.
Also, as Andy said, the electrics are more complicated too.
I will have a D2 in my shop in a month or two to work these things out.
Old May 8th, 2015, 03:26 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I did use 'not that dissimilar' very loosely...
Old May 8th, 2015, 03:40 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
The driveshaft difference is .5".
Old May 11th, 2015, 05:54 PM
mattwhite
Matt White
94 D-90
I figured I'd give a quick update.
I only have about 20 miles on it so far, I'm still work through a bunch of minor details. Overall impressions so far: "Damn! This thing pulls!" I did try a couple steep inclines, and it just motors up them with no complaint. The old 3.5 was ragging out 2nd gear and still barely moving on the same inclines.
Over the weekend I did get a chance to install some fun stuff, a little off topic but check it out-
Old May 11th, 2015, 06:19 PM
So do you actually get up in the air with that thing??
Old May 11th, 2015, 06:32 PM
mattwhite
Matt White
94 D-90
Haha, it's all part of my Evel Knievel plan.
I needed the motor to hit the ramp, then the awning to rapid deploy and float over the 37 LR4's in the mall parking lot.
Old May 11th, 2015, 06:47 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Originally Posted by mattwhite View Post
Haha, it's all part of my Evel Knievel plan. I needed the motor to hit the ramp, then the awning to rapid deploy and float over the 37 LR4's in the mall parking lot.
I don't see any reason why that shouldn't work! ;-)
"Barry is correct!"
Old May 12th, 2015, 11:22 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Adapters back in stock. Just shipped five. Have eight left.
Old May 13th, 2015, 11:21 PM
D110DC's Avatar
D110DC
Pete
66 SIIA, 70 IIA, 97 D90
PM sent.
Pete
1966 ECR Series IIA
1970 Series IIA (Stella)
1997 D90 ST
2011 LR4 HSE
2010 Range Rover Supercharged
Sadly gone (some more sadly than others):
1983 D110 Double Cab 300 TDi
1989 RRC
1996 D1
2006 LR3
2008 RR
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
