GM Gen 4 conversion including LS - Page 37 - Defender Source
Old April 20th, 2015, 07:00 PM
SGS714's Avatar
SGS714
Scott Striglos
3xRRC 2xD90 2xD110 Series II, IIA
Originally Posted by dannyp View Post
First post here, a long time lurker, lots of rover envy here !
Scott,
You just made a decision of what I should do with my 95 lwb RRC ! I would do the same conversion when the time come. I assumed you changed the borg warner into lt230?
Danny
Danny, Welcome to the forum. Correct, I haven't had a BW for quite a while and I had already done the LT230 upgrade on the previous RRC I robbed everything south of the frame from.
Thank you,
67 Series II
71 Series IIa 88" ACR 2.8 Power Plus
89 RRC 2 door VM 2.5TD
93 D110 NAS #327
94 2x D90 NAS #'s 1076 ACR 4.8, 1161 SBC
94 D90 NAS now a D110 HS 2.8 aka Project Wolf
95 2x RRC
1-SWB,Doing the LS Gen IV 98% Done
1-LWB 300tdi
Old April 21st, 2015, 12:58 AM
Landy_Andy's Avatar
Landy_Andy
Andy
I would have had my engine all back together but someone ordered the wrong ARP head bolt kit.... Doh
So, I dry assembled it anyway.....
Old April 23rd, 2015, 08:38 PM
dannyp
Danny Pierenardy
1995 RRC
Scott, thanks for the reply
Btw, is your instrument panel are all worked / connected properly?
Markiw, you have a pm'ed
Danny
Old April 26th, 2015, 11:45 PM
Dsilby's Avatar
Dsilby
Daivd
97 D90
Hey guys
I might have missed this reading through all these pages.
But how does the stock Defender axles handle the power and torque of the LS?
Being my 97' D90 is AWD with the transfer case, I was worried if I went down this road that the new engine would burn these stock axles and transfer case right up.
Thanks!
Old April 27th, 2015, 01:50 AM
why do you think the engine will "burn up" the axles and transfer case?
are you planning to drag race your defender? abusively drive it?
Old April 27th, 2015, 05:25 AM
UL1700
James
Defender 50th
Hell Yes
Old April 27th, 2015, 08:00 AM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
Originally Posted by Dsilby View Post
Hey guys
Thanks!
If this is truly an issue.....
New engine mounts must be made to mount the LS. Why not go ahead and install GM axels and T case etc. also? Seems no more invasive to me.
Old April 27th, 2015, 09:01 AM
??? This conversion uses the stock engine mounts.
The transfer case is fine. Axles could use upgrades if you are using the truck off road, which is the case regardless of the engine.
Old April 28th, 2015, 01:49 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Got my ICT Billet EGR blanks today... Bit of bling
Old April 28th, 2015, 07:07 AM
Himalaya's Avatar
Himalaya
Mark WS
1995 Nas, 86 D110, 97 Hummer H1
You should be changing the half shafts to handle the horsepower. Stock ones will break.
Old April 28th, 2015, 09:18 AM
1. I think the whole point of the adapter is so you CAN use the stock rover tcase, driveshafts and axles. Going with other drivetrain components sort of defeats the purpose.
2. You should easily be able to run stock two pin diffs and halfshafts with an LS7.
3. Drive the rover like a normal person and you have nothing to worry about.
4. If you plan on driving abusively, then uprated components can't hurt.
Old April 28th, 2015, 09:34 AM
phoenix37's Avatar
phoenix37
john
Ive got a 1000 miles on my LS swap (stock t case and axles,33" tires) and drive it like a teenager...nothing busted yet.. if and when i snap a shaft Ill do an upgrade.
Old April 28th, 2015, 03:59 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Anyone got their GM truck a/c pump & bracket going spare... Some dummy scrapped his... Doh !
Old April 30th, 2015, 07:31 PM
bansheeboyo
scott
defender 90 300 tdi
Hi are these kits still available ?
Do they work on 300tdi mounts ?
Are they compatible with right hand drive vehicles ?
Old April 30th, 2015, 10:24 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
No, and yes. The 300tdi mounts have to be cut off, then weld on my mounts.
Old April 30th, 2015, 11:20 PM
SGS714's Avatar
SGS714
Scott Striglos
Danny
No they aren't. Still in the "work in progress category"
Thank you,
67 Series II
93 D110 NAS #327
95 2x RRC
1-LWB 300tdi
Old May 1st, 2015, 02:18 AM
bansheeboyo
scott
defender 90 300 tdi
Pm sent
Old May 1st, 2015, 12:10 PM
Landy_Andy's Avatar
Landy_Andy
Andy
First test fit
Gonna need to go back an inch to accomodate the Allisport rad.... but we know that already
Just enough clearence for the oil pan to the 3 link but will prob swap it out for a Camero or after market one once things are up & running. Will be ok for the time being.
Old May 4th, 2015, 06:02 PM
djm's Avatar
djm
dwayne
1993 defender 110
Originally Posted by nmarkiw View Post
Three in Colorado. Two in Australia. One in Canada.
who were the two in australia? if you dont mind me asking/or them knowing? i wouldnt mind chatting to them about there build.. im in aus and have purchased a 6 litre for this conversion but unsure about the 6l80e we have here as its not a 4wd version as spoken about needing earlier in this thread as our 6l80e autos only came in our rear wheel drive commodores.. wondering how they went with your adapter? if they needed to change anything or it all worked as it should?
Old May 4th, 2015, 06:13 PM
UL1700
James
Defender 50th
Hi, one of them is me (in vic) my build thread is here http://www.defendersource.com/forum/...ild-58134.html It has sat idle for a while due to other commitments but I have just started picking up the pieces again (monster rad now installed and wright up to follow) I will PM you my phone number if you want. If you don't want the go with the 6l80 I have a bell housing to mate the LS engines to the ZF 4 speed, was about to list it on ebay!
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
