GM Gen 4 conversion including LS - Page 28 - Defender Source
Old December 18th, 2014, 04:49 AM
UL1700
James
Defender 50th
Originally Posted by mattarm View Post
Wow, that's one ugly shifter! (IMHO LOL) Lets hope that the TUTD part works with their other shifters... For me, I will stick with OEM.
Old December 18th, 2014, 08:01 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I actually like it. I wonder if you could mount on a R380/LT77 tunnel and extend the top part. I think the end result wouldn't look far off from a normal R380 with an alloy knob.
Old December 18th, 2014, 08:06 AM
Do the guys in the viddy resemble the product in any way?
Beuller?
Beuller?
Old December 18th, 2014, 08:25 AM
phoenix37's Avatar
phoenix37
john
Beuller?
Beuller?
Hilarious!
Old December 18th, 2014, 12:36 PM
phoenix37's Avatar
phoenix37
john
playing around with some junkyard parts. Pontiac G8 shifter and DiscoII console. kind of like it better than the lokar.
Old December 18th, 2014, 12:40 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Lift it up to be flush on a mount & a nice powder coated/textured trim panel to fill the gap & it'd look sic... Prob work out cheaper too
Old December 18th, 2014, 12:56 PM
phoenix37's Avatar
phoenix37
john
Still planning to go with Nicks cable and NAS style console. Im not sure the linkage will work but had the disco console already and the g8 shifter was cheap so thought id mock it up.
Old December 18th, 2014, 02:17 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Can anyone tell me the LR part number for this? Don't want to drop $120, but do want to make sure I pickup the correct part.
Originally Posted by dave_lucas View Post
Another part sourced
For this swap you need to buy the hi/ lo - CDL mounting plate from an automatic 1994 - 1998 Discovery series I. this is where your CDL attaches and the plate for the shifter. I suppose if you have a 1997 with an automatic you might not need this part?
They are pretty pricey if you buy one new online ~ $120 so I opted to go to the local pull and pay and got one for $9.
Here is a picture for future reference (lifted from Ashcroft where they sell for 60 GBP).
Question for you Nick. Are the 4 holes in your Adapter in the same location as the automatic Discovery transmission? From looking at both it seems so but just wondering if you kept the exact same location.
Old December 18th, 2014, 02:19 PM
Jwillia's Avatar
Jwillia
Justin
87 ROW build in progress
Steal one from a disco.
Old December 18th, 2014, 06:38 PM
SGS714's Avatar
SGS714
Scott Striglos
3xRRC 2xD90 2xD110 Series II, IIA
Tons of them on eBay...you can count on Paul Grant...He goes by spupilup. Or call him direct and he will put up a buy it now listing for you.
Thank you,
67 Series II
71 Series IIa 88" ACR 2.8 Power Plus
89 RRC 2 door VM 2.5TD
93 D110 NAS #327
94 2x D90 NAS #'s 1076 ACR 4.8, 1161 SBC
94 D90 NAS now a D110 HS 2.8 aka Project Wolf
95 2x RRC
1-SWB,Doing the LS Gen IV 98% Done
1-LWB 300tdi
Old December 18th, 2014, 06:43 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
can anyone tell me the lr part number for this? Don't want to drop $120, but do want to make sure i pickup the correct part.
frc8558
Old December 19th, 2014, 09:12 AM
phoenix37's Avatar
phoenix37
john
Here is another console option featured in this months LRO magazine. Finally.. I might go this route instead of the ashcroft NAS console. Let me know if anyone else is interested and maybe we can do a group buy .
http://www.bordermotorsport.co.uk/in...roller=product
Old December 19th, 2014, 10:09 AM
jmason's Avatar
jmason
John M
2000 P38 4.6HSE
Originally Posted by nmarkiw View Post
The P38 adapter is next. Currently working on that.
P38 adapter you say? I was under the impression that the finicky electronics of a P38 rendered such engine swaps as over-complicated and not really worth it...
I am very interested in that. Where will you be posting the information about the P38 escapades?
2000 P38 4.6HSE
Old December 19th, 2014, 01:39 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Custom Aluminum Radiator
12" won't fit. 11" are the largest we can use on this radiator(Defender). The RRC/D1 radiator can take 12" fans.
No room for a shroud. Just clears the water pump pulley.
Umm.... looked back & found the pic you posted a while ago, is tight isn't it & there the slimline fans too. How much room is behind the engine, will it stand the engine mounts being moved back 1.5" to allow a shroud & the medium duty fans to be used ?
Old December 19th, 2014, 01:51 PM
phoenix37's Avatar
phoenix37
john
the fans are actually a medium profile not slim line.
http://www.jegs.com/i/SPAL/063/30101500/10002/-1
Old December 19th, 2014, 02:20 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Must have clicked the wrong linky.... umm, still gonna be real close with the Alisport rad I have, the shroud is ~3/4" thick. An extra inch back on the engine would fix it though.
Old December 19th, 2014, 04:08 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
You don't want to run a shroud with these fans. You will ram air more flow than these fans will take. Leave the area around the fans open.
Old December 19th, 2014, 04:19 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Umm... rad already has the shroud on it & my truck will spend 99% of it's time crawling round the bush, It'll see very little road use.
I could use the mounting bosses that are welded onto the rad to make an open support frame that'll hold the fans close to the core.
Would still like to keep the option of using a shroud open so think I'll move the engine back an inch just in case.... unless that'll foul the bulkhead ?
Old December 19th, 2014, 05:02 PM
UL1700
James
Defender 50th
Assuming its the same as the Holden version, the top bezel floats by about 15mm. This means that your trim plate needs to include 4 studs to fix the top bezel at the correct height and cover the excess hole in the defender tunnel. The linkage to the gearbox is a simple rod (mine came with the gearbox) and it all looks factory I will write up what I have been doing with mine on my build thread when I sort out a few little details. I also need to finish the cad drawing so the cover plate can be profiled... Total cost next to nothing if you get the shifter with your box
Old December 19th, 2014, 08:06 PM
vanroth
Justin
SIII
Nick, do you have a price list and/or BOM of everything needed? Will these fit 109's fitted with the original 2.25 or is this for Defenders only (i.e. would a Defender LT230 bolt up?). I realize that there would need to be axle upgrades as well, but this would get one step closer to being able to drive on the highway (and a easier path to A/C). A 109 NA Diesel can only move but so fast...
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
