October 22nd, 2014, 05:19 PM
Justin
87 ROW build in progress
Originally Posted by Landy_Andy
Won't the original ones fit ?
Nick can give way more input, but from what I can tell. The older fbody ones would work. The truck ones angle out too much. We are gonna need some that tuck in close and exit downward towards the rear.
October 22nd, 2014, 05:35 PM
Nicholas Markiw
1994 NAS D90 LS 5.3L
No, the LS1 won't fit either. That one fit Clay's setup where the engine was back 2" more.
October 24th, 2014, 04:20 PM
Matt
1993 D110
Did that motor come from Arkansas?
Originally Posted by SGS714
No it couldn't be the same LC9. Did yours look like this?
October 24th, 2014, 09:33 PM
Scott Striglos
3xRRC 2xD90 2xD110 Series II, IIA
Yes Paragould.
Was planning on picking it up in early December....duck hunt near Paragould the first week of the 2nd season every year.....but then he told me the shipping rate and it was a no brainer so it will be here Tue.
October 26th, 2014, 03:12 PM
john
anyone have photos of how they mounted the ECM and routed the harness?
October 26th, 2014, 03:49 PM
Nicholas Markiw
See photos...
October 26th, 2014, 03:57 PM
john
whats the ecm bolted to? Did you fab a bracket or is that factory on NAS trucks?
October 26th, 2014, 04:01 PM
Nicholas Markiw
I fabricated the plate. Then bolted it to the factory air box shelf (NAS).
October 26th, 2014, 07:38 PM
Clay DeWan
5.3L beastie
Sorry folks and nick I did originally kick nick off the ledge into the forum world. When someone comes up with a revolution you want to be part of it even if you are on its coats strings.
October 27th, 2014, 08:51 PM
Andy
For those on Crack book, check out 'Les Richmond Automotive' down under in Aus... His LSx powered RaRo's rolling on 35's are real nice work and safe too as they have to pass stringent engineering & safety trials before being signed off for use on highways. His hybrid 9" / LR rear axle looks interesting but I think for similar or less you could build a full custom 9" setup here.
https://www.facebook.com/lrautomotive
October 27th, 2014, 09:08 PM
William Skidmore
SIII 109 SW
Looks like his hybrid 9' is from Ashcroft.
October 27th, 2014, 09:31 PM
Andy
I wasn't sure, reading post it looks like the diffs come in from the U.S. Either way, I think cheaper to build custom using Ruffstuff housings & junkyard parts
I believe Ashcroft have ceased production of the Force 9 axles, I know Jim Marsden has swapped his out for Spidertrax as he kept breaking them.
October 27th, 2014, 09:40 PM
William Skidmore
SIII 109 SW
I went to the shops website. Think I read it correctly.
October 28th, 2014, 07:31 AM
Scott Striglos
For those of us doing or considering the LS4 in a RRC check out the speedo and tach cluster down about 20 posts on his Facebook Page. I've reached out to them for more information. Will share with Nick to get his thoughts if it proceeds.
Thank you,
67 Series II
71 Series IIa 88" ACR 2.8 Power Plus
89 RRC 2 door VM 2.5TD
93 D110 NAS #327
94 2x D90 NAS #'s 1076 ACR 4.8, 1161 SBC
94 D90 NAS now a D110 HS 2.8 aka Project Wolf
95 2x RRC
1-SWB,Doing the LS Gen IV 98% Done
1-LWB 300tdi
October 28th, 2014, 09:20 AM
I'm not sure this is an accurate account..... Jim was using prototype axles that had known weaknesses. He did not get the parts upgraded, despite being told about the problems.... I'm not sure he completed a race this year with the new car due to mechanical failures including killing the GM engine twice.
October 28th, 2014, 11:32 AM
Andy
I stand corrected....
October 29th, 2014, 09:15 AM
Justin
I found a nice l99 out of a escalade 2011 with 11k miles with tranny for 6700 here in socal if someone is looking
October 29th, 2014, 10:25 AM
David Frank
1995 ST #2516
Pardon my ignorance, but I thought l99 were only in automatic ss comaros.
"Barry is correct!"
October 29th, 2014, 10:39 AM
Justin
It's a 6.2 2011 to whatever code it is.
October 29th, 2014, 10:50 AM
David Frank
1995 ST #2516
Is there a web-link to the sale?
"Barry is correct!"
» Recent Discussions |
