GM Gen 4 conversion including LS - Page 15 - Defender Source
Old March 23rd, 2014, 06:16 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
On another note, I did several full power launches today. (high range on asphalt) Barking 35s through first gear really puts a gin on your face!
Old March 23rd, 2014, 06:28 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Wow... I should have driven up for that!
Old March 23rd, 2014, 06:39 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
You are welcome to take it for a drive.
Old March 29th, 2014, 09:56 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Originally Posted by nmarkiw View Post
Well, the VDO tach (stock or afermarket) won't work with the Gen IV. Works with the Gen III. It needs to operate at 5v square wave. Talked to SpearTech and they say use the AutoMeter gauges. In addition, the aftermarket VDO coolant temp gauge reads incorrectly. About 8-10 degrees low. It is time to jump ship regarding VDO.
Going with the AutoMeter 2635, 2698, and 5284.
Tach problem solved. The MSD 8920 tach adapter converts the 0-5v to 0-12v signal to drive the VDO tach.
Old March 29th, 2014, 10:46 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Good to hear. Im not a big autometer fan. The bezels look out of place in everything Ive ever seen them in.
-Jeff
I don't like the looks of the Autometer either. At least the VDO Vision Black match the stock gauges.
Old March 30th, 2014, 10:26 PM
surf110's Avatar
surf110
Ze
130 Project
Test Drive
Went by Nick's place today and test drove his D90 with the GM GenIV.
All I can say is WOW!
Turn the volume up to watch the video. Enjoy.
Old March 30th, 2014, 10:38 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Sweet!!!!!!!!!
Old March 31st, 2014, 12:43 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Gave me tingles
Old March 31st, 2014, 03:27 PM
CDeWan
Clay DeWan
5.3L beastie
Nick's Gen III creation
Turning just over 1,000 RPM doing close to 60 purs like a kitten.
Name:	nick gen III creation.JPG
Old March 31st, 2014, 03:33 PM
Damn it man. Replace that fuel gauge!!
Old March 31st, 2014, 03:40 PM
that just doesn't seem right
Old March 31st, 2014, 03:41 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Agreed change the fuel gauge to VDO. Can you post a photo of the auto shifter?
Old March 31st, 2014, 03:45 PM
CDeWan
Clay DeWan
5.3L beastie
fuel
There is a problem with going directly to a VDO fuel or else I would have done it. it is a signal that VDO does not make a direct (or sell an adjustable guage for). You can see picks of the shifter that nick modifies for the 3.9 defenders done in the "SVX build" in the resto thread. If you need a closer shoot look in the tech section under lokar shifter as I believe I posted a thread awhile back.
Old March 31st, 2014, 03:49 PM
The VDO fuel gauges work with the stock Land Rover senders. You don't need to do anything other than change the gauge. You want the model 301-105, 240 to 33 Ohm range gauge. I've had one for years.
Old March 31st, 2014, 03:50 PM
Its broken. Should be reading empty.
Old March 31st, 2014, 03:55 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Thanks for the info. I am off to buy one.
Old March 31st, 2014, 07:04 PM
CDeWan
Clay DeWan
5.3L beastie
me too!
Thanks for the info just ordered the last one that summit had in stock before Nick could. Sorry Nick, I will bring my nice gauge by so you can pine for one.
Old March 31st, 2014, 07:24 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
I already ordered mine.
Old March 31st, 2014, 07:41 PM
CDeWan
Clay DeWan
5.3L beastie
yes
Yes but I called pretended to be you and asked if they could change my order from a VDO guage to a set of fuzzy dice and "truck nuts" now that your Defender has some serious balls on it.
Old April 4th, 2014, 10:03 AM
mattwhite
Matt White
94 D-90
Update on my project:
I got the drivetrain in the 110 around the end of February, but of course life got in the way and I haven't touched it since then. But now I have a goal, we are planning a Memorial weekend trip to Moab. There's only a 50/50 chance it will be done by then but at least it's something to work towards!
So the engine is in but it's in the wrong spot. My 110 was originally a 4 cylinder and someone at some point swapped in the 3.5 V8. It seems that they just welded the V8 mounts to the frame where ever the motor landed and not in the factory location. Anyways the t-case is an inch to far back and the intake hits the hood. So I'm going to cut the mounts and move them to the correct location.
This weekend it's wiring! I got my efi harness modified by speartech and it looks sweet. However, I couldn't bring myself to marry the brand new efi harness to a 30 year old rats nest so I picked up a 14 circuit universal chassis harness from Kiwk wire. Wish me luck!
Name:	photo 1 (1).jpg
ID:	92372   Click image for larger version
Name:	photo 2 (1).jpg
Name:	photo 4 (2).jpg
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
