GM Gen 4 conversion including LS - Page 118 - Defender Source
Old December 18th, 2017, 01:46 PM
defender1844
Amit Likhyani
Nick:
nick.markiw@rw-eng.com
Old December 18th, 2017, 07:01 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by Jasonray2004 View Post
Please contact me as I am interested in purchasing a kit for a 1986 D90 LHD. Putting in a 5.3, 4L60 4X4 Transmission.
My email is jasonray200 yahoo com
520-204-6760
------ Follow up post added December 18th, 2017 02:37 PM ------
jasonray2004 yahoo
------ Follow up post added December 18th, 2017 02:42 PM ------
Dropping an LS 5.3 , 4L60 into an 86 D90. Any advise?
------ Follow up post added December 18th, 2017 02:43 PM ------
It looks like Nick Markiw is the tip of the spear on these kits. Anyone have contact info?
You do realize that the 4L60 will require the t'case moving back about 8", for drop in you need to be running a 6L80 or go manual with a NV4500. It's discussed way, way back at the start of this thread... happy reading !
Old December 23rd, 2017, 02:42 PM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Hi all...
Have anybody done a cold air intake for the rotated truck intake?
I'm for the Russian pencil
Old December 23rd, 2017, 08:16 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Someone here has this sweet 110 and I saved the photo from their intake. So far it is the best idea I have seen and I plan to route mine in a similar manner. Sorry I can't give credit to this truck--I didn't save who here it is but it sweet work...
Name:	Air Intake.jpg
Old December 23rd, 2017, 09:30 PM
Cliffman
Dane Walker
1988/ 110
Haha! I did the exact same thing for the same reason!
Old December 24th, 2017, 12:28 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Do you know where you got the intake tubing?
Also, how you secure it? Weld a tab and bolt to frame?
Old December 26th, 2017, 09:56 PM
dogbite's Avatar
dogbite
Paul D
95 D90 ST & SW
4 days later.... I made it through the entire thread.... and just might have to try this!! PM coming your way Nick?
Old December 26th, 2017, 09:57 PM
dogbite's Avatar
dogbite
Paul D
95 D90 ST & SW
And Chris, hoping to pick your brain a bit too once I get organized.
Old December 28th, 2017, 10:18 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
No sweat. you can also check mine out and drive it if you'd like. Dave has one near by too. Just drop me a line.
Old December 28th, 2017, 02:38 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Not much room left to relocate the battery to under the hood, which I had hoped to do. bah!
Current fleet: '85 Ninety 3.9 V8i Auto SW,'07 BMW 335Xi.
Old December 28th, 2017, 04:04 PM
Factoid's Avatar
Factoid
Mark
Three criminals seeking revenge
Plenty of room behind the engine in my build.
1976 Series III 109 "Montoya" ("You killed my father, prepare to die")
1988 Defender 90 LHD "Vizzini" (speed demon from Sicily)
1987 Defender 90 MOD LHD "fezzik" (giant rock thrower)
1975 Porsche 911 hot rod
1964 Porsche (Beck) 904
Old December 28th, 2017, 05:11 PM
Z06801
Park
1995 LWB RRC
Attachment 340585
That looks great! Does the LS fit in about the same spot as the stock motor in the Defender? My classic looks much tighter to the fire wall
Old December 28th, 2017, 05:24 PM
Factoid's Avatar
Factoid
Mark
The LS sits significantly farther forward in order for the TC shifter to sit in the stock position. This creates a significant space behind the engine for the intake plumbing or battery. I'm using a 2012 Camaro L99 vs the more typical truck LS which provides a lower intake manifold for hood clearance and the forward facing intake, but does not have as much low rpm torque as the truck intake.
Old December 29th, 2017, 12:50 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Given the amount of torque even with the lower plenum (based on the torque curves you and I shared) I don't see the lower plenum to be a detractor anymore. The shorter intake distance to the front fender well is pretty compelling and you have a very clean install.
On a separate note, I took my buddy out for a "first ride" to show him and he thought it was a little choppy on acceleration. It was cold out and the tires were also a little wet so I had to explain that the "choppy feel" and the reason we were sliding sideways to the curb (off camber road) was because all 4 tires were spinning, LOL. The thing is a bat out of hell when it wants to be, that is for sure.,..
Old December 29th, 2017, 02:08 PM
Factoid's Avatar
Factoid
Mark
When I was first thinking about this conversion, I spent a couple months looking for a low mileage truck 4x4 engine/tranny. No luck. Finally, I was talking to Nick and he explained how easy the 2x to 4x conversion is and sells a kit with the seal, plugs and modified 4x tail housing (trimmed to clear the TC). It took less than 20 minutes to convert and most of that was trimming the end of the tranny output shaft. About that time, the 20k mile 2012 Camaro engine/tranny popped up on eBay. It was meant to be!
The WP configuration was ideal for radiator plumbing and allowed a straight shot for the intake plumbing to the right wheel well. Also, four 1 1/2" spacers allow the corvette accessory bracket to be used with a very minor clearance trim to clear the steering box adjuster.
I think you and I both agree that the conversion was a big learning experience, but if we did it again it would take 1/2 the time. Still brings a huge grin to my face each time I drive it!
Old January 6th, 2018, 02:33 PM
stancey's Avatar
stancey
steven stancey
1988 Defender 110 LS, 1993 130 tdi
Hey everyone, having some trouble wiring my vdo speedo. Really my last gauge not working for my ls swap. Itís a non-gps vdo gauge.
I have a disco 1 transfer case with a two wire harness coming out. This is how itís wired.
Black wire from transfer case position 2
Ground from car position 3
Power position 4
Green from transfer case green position 6,8
Speedo has power, but not reading mph or odometer. Any help is appreciated. Thanks
Old January 6th, 2018, 03:26 PM
Looks like you tried to wire it up as a hall effect sender. Discos have an inductive sender.
4 - switched power
3 - ground
7 and 8 to the two wires on the sender.
Hopefully you have not fried the sender. 2 sends power to it and straight power across it without a resistor can cook them.
You can do 2 and 8 to the sender, but you need to add a resistor inline to limit the current. FYI, you can get a multi plug connector for the speedo.
Old January 6th, 2018, 07:39 PM
stancey's Avatar
stancey
steven stancey
Thanks. Well it looks like I fried the sender. I also tried the yellow wire that speartech puts in the harness for the speedo so I can calibrate the it with pulses, but that didnít work either bc the ecu isnít sending me any pulses. Iíll check with nick Monday and see if that was turned off in the flash. Iím not sure why I thought it was a Hall effect sender. Oh well.
Old January 6th, 2018, 07:43 PM
Have you calibrated the speedo or manually entered a pulse number? It wonít display a speed until you do.
Old January 6th, 2018, 07:58 PM
stancey's Avatar
stancey
steven stancey
I tried to calibrate it using the auto method, but it basically gave me the message indicating it wasnít receiving pulses
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 05:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 11:58 AM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 08:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 04:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 08:33 PM
