Glow plugs with oil on them?? - Defender Source
Old March 27th, 2016, 08:22 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Hi guys,
Getting ready to pull the head. I noticed that 3/4 glow plugs removed are wet with oil.
What is that mean?
Thank you.
Old March 27th, 2016, 09:06 PM
DailyDrivenDefende
Michael
Injectors.
What yall think?
Old March 28th, 2016, 12:46 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
1st, I'd take the injectors to a diesel service shop and have them "pop" tested & checked for spray pattern. Parts for these are hard to come by in the US, so bad injectors will have to be replaced with new units. The service books say to replace the entire injector set at every 90K miles, relaced mine after 120K even though they seemed to still operate properly.
Question, 200 or 300Tdi ?
You'll need a new set of copper seats at the base of the injector hole in the head, you can omly seat them once.
Old March 28th, 2016, 12:55 AM
It just means those plugs were not working. Nothing more. Nothing to worry about.
Old March 28th, 2016, 01:22 AM
DailyDrivenDefende
Michael
Ordered 4 glow plugs. Thinking about getting these injectors rebuilt(200tdi).
BTW, just out of curiosity, where is the oil coming from? I see that my combustion chambers are dry.
Old March 28th, 2016, 05:06 AM
is that engine oil or diesel covered with soot?
Old March 28th, 2016, 07:52 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
If you can't find a local shop, metro fuel injection in MA do them (and the pump). You ship them the injectors, and you can source the parts (nozzles) yourself and send them there as it is cheaper.
Old March 28th, 2016, 08:13 AM
Ordered 4 glow plugs. Thinking about getting these injectors rebuilt(200tdi). BTW, just out of curiosity, where is the oil coming from? I see that my combustion chambers are dry.
It is diesel.
Get a set of injectors from Robert Davis.
Old March 28th, 2016, 08:46 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
No reason to ship them cross country. This shop has done many and is knowledgable in the pumps and injectors. Have been used by several here locally including myself. http://www.dfispdx.com/
Ryan
84 110SW County LHD
07 L322 Vogue
Old March 28th, 2016, 09:03 AM
They are Bosch injectors as found on literally hundreds of thousands of vehicles. If your local diesel shop can't clean them up they shouldn't be in business!!!
Old March 28th, 2016, 09:40 AM
It is not the cleaning them. Setting the pressures equally on the two stage injectors is not a simple job and requires special tools and knowledge. Most diesel shops do not have the expertise.
Nozzles need to be replaced and can't be "cleaned". The nozzles have a limited life.
Glow plugs vs relay on 200Tdi Axel Defender Technical Discussions 39 January 6th, 2014 01:00 PM
glow plugs s3landy Defender Technical Discussions 7 November 29th, 2012 12:51 PM
WTB 200tdi Glow Plugs d90frank Wanted 0 August 1st, 2010 01:51 PM
300 TDI needs new glow plugs. Bosch or original Beru? sundogcwolfe Defender Technical Discussions 11 December 17th, 2009 10:36 PM
300Tdi glow plugs artm Defender Technical Discussions 9 November 21st, 2004 12:10 PM
