Glow Plugs stopped working - Defender Source
Old March 29th, 2015, 02:16 PM
defenderholty's Avatar
defenderholty
Russell
1985 LR Ninety 200tdi
I have an 85 LR Ninety 2.5NA. I bought it around 2 years ago. It has had a a few quirks and rusty problems, nothing I haven't been able to figure out. Now the glow plugs stopped working. When I turn the key to the position where the glow plugs are supposed to come on they don't.
It's still a little cool here to crank it without them. I looked for a fuse, but I didn't find one that was for the glow plugs. Any one? I guess I'll start with chasing wires.
-I looked a bit through the forum and didn't find anything specifically mentioning my problem.
thanks
Old March 29th, 2015, 03:04 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Sounds like your relay went out.
I have heavy duty ones available that are simple to wire if that helps.
RDavisinVA
Old March 29th, 2015, 03:27 PM
defenderholty
Russell
Sounds like a plan. Where is the relay in my truck?
Old March 29th, 2015, 03:53 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
If your wiring hasn,t been buggered about the glows are wired straight to the back of the ign switch. Remove the big brown wire with the red stripe from the first glow plug (yellow/black wire) and check for voltage when you turn the key just before the engine turns over.
Could be the ign switch is buggered or wire could have come off.
There no fuses or relays. Good luck in your quest
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 29th, 2015, 04:21 PM
defenderholty
Russell
I'll give it a look.
top
Front blinkers stopped working meow Defender Technical Discussions 8 September 16th, 2013 08:22 AM
Headlights stopped working JTull Defender Technical Discussions 17 November 29th, 2012 06:26 PM
AC stopped working. TxEddie1111 Defender Technical Discussions 5 September 23rd, 2010 03:27 PM
Indicators stopped working ... leastonce Defender Technical Discussions 1 November 2nd, 2009 10:25 AM
wipers stopped working MontanaD90 Defender Technical Discussions 1 February 25th, 2008 01:27 PM
