glow plugs - Defender Source
Old November 28th, 2012, 06:27 PM
s3landy
Mike Wallace
glow plugs
I had a new set of Bearmach glow plugs for my 200 tdi just in case I needed them. Well now I need them and they won't fit all the way in. Has anyone else encountered this before. I managed to lightly file one down to get it to fit but I will be getting a new set instead. What are your thoughts on Beru as opposed to genuine ?
Old November 28th, 2012, 07:13 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Beru is the way to go. I stick some anti-seize compound before fitting.
- Charles Eames
Old November 29th, 2012, 06:27 AM
s3landy
Mike Wallace
I must have got a dud set ??? No one else has ever encountered this ?
Old November 29th, 2012, 06:56 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
What's the Beru part number?
Semper Fi!
Old November 29th, 2012, 08:05 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The problems that I have had with factory plugs is getting them out, thus JFD's recommended anti-seize, (however that doesn't stop the tip from getting crudded in) and getting the washer out.
Land Rover 110
Old November 29th, 2012, 10:19 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I changed mines couple months ago, during engine rebuild, and 2 of them were badly stucked, had to hammer them out with a skinny and long punch and a big hammer plus lots of penetrating stuff. Kind of frightening
- Charles Eames
Old November 29th, 2012, 11:35 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
What washer??
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old November 29th, 2012, 12:51 PM
Capt Milks's Avatar
Capt Milks
Seems that you got the "T" shirt too. I had one stuck but the shaft came out and left the tip in the head. I feel your pain.
------ Follow up post added November 29th, 2012 12:53 PM ------
Originally Posted by roverman2010 View Post
What washer??
You have a brass crush washer at the end of the injector. I have had them stay in the head after removing an injector. It was a Pita to get out.
Land Rover 110
WTB 200tdi Glow Plugs d90frank Wanted 0 August 1st, 2010 01:51 PM
300 TDI needs new glow plugs. Bosch or original Beru? sundogcwolfe Defender Technical Discussions 11 December 17th, 2009 10:36 PM
While changing spark plugs mdmccallum Defender Technical Discussions 9 November 2nd, 2005 09:12 AM
300Tdi glow plugs artm Defender Technical Discussions 9 November 21st, 2004 12:10 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
