Glow plug wiring differences ... - Page 3 - Defender Source
Old November 27th, 2011, 02:29 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by Manimal
I found the glow plug relay. Don't laugh. It was located in the battery box. I was looking in the engine compartment because that is where RN told me they put it. I still haven't found why its not working any more. RN told me that it connects to the battery but not necessarily in the battery box. I suppose I will have to open the harness and trace the brown wire?
There is also a red mystery wire that that goes from the battery to a mystery relay or ground of some sort (see picture 3 & 4). Anyone know what this is? Do I need these? Can I remove them?
Looks like a resistor and a good source for a short and/or shock. Whatever it is, it's not presently in use.
Semper Fi!
Old November 27th, 2011, 02:34 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks. I'm getting rid of it pronto.
Old November 27th, 2011, 05:55 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I got rid of it and for some bizarre reason my glow plugs are now working again.
Old December 27th, 2011, 01:52 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Re-Hash the Glowplugs
I got a new ignition switch, and the connections are different.
I hook up my glow plugs like the picture below, the only problem is that I with the (white/red) connected to the ignition the glow plugs never turn off, they turn on and stay on.
With just the (white) from the trucks harness, the thick (Brown) to the battery, the (black) to ground, and the (yellow/black) to the dash light, glow plugs work as they should.
Is this Kosher?
Old January 16th, 2012, 10:44 AM
Surfin' Elvis
Chuck
95 RRC 300tdi/wvo conversion
I used a remote 12v starter relay, wired direct to my accessory battery, triggered by a momentary push button on the dash. Ran the output from the relay to a 4-gang fuse block and wired the glow plugs parallel, each one fused with a 25-amp fuse. In this set-up, if one glow plug shorts, at least the others won't be affected. The added benefit is that, with the push button activation, the relay only cycles when I need it to cycle, which should extend its years of service. No timer installed, but trial and error gave me an idea of how long to depress based on how the engine turns over at various outside temps. Total cost less than 40 bucks. Fool-proof so far.
wiring
Diesel Ignition switch with glow plug tomaco1 Defender Technical Discussions 18 December 31st, 2011 02:31 PM
Pin-out for the PRC 6913 glow plug relay? dmarchand Defender Technical Discussions 7 July 10th, 2007 05:51 PM
Glow Plug Relay Michael Defender Technical Discussions 1 March 16th, 2006 02:28 PM
what does this plug in to? mattdh Defender Technical Discussions 6 November 2nd, 2004 11:59 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
