Glow plug wiring - Defender Source
Old November 9th, 2013, 01:15 PM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
Glow plug wiring
Anyone know where the wiring to the glow plugs connects to?
The diagram shows a "ballast resistor". Is that just a wire? Where is it?
I see the wire from the starter switch disappear into a bundle, but not sure where it goes to connect with this ballast resistor. I have an orphan wire to the glow plugs. The wiring is most likely from the original NA diesel. It's possible they were never hooked up after the tdi conversion. Help, it's getting cold!
Old November 9th, 2013, 02:17 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
What year?
We have a glow plug controller manufactured for the Mercedes conversions that is adjustable from 1 - 120 seconds that works automatically when the key is switched on that will work on your 110, if you run out of options.
The ballast resistor drops the current for the early 90 & 110 and the series vehicles.
If you switch to the later glow plugs, you won't need it.
RDavisinVA
Old November 9th, 2013, 03:57 PM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
It's a 1984 Ninety with a disco 200 tdi. I took this opportunity to put new glow plugs in since the old we're falling apart. I traced the wire it behind the instrument cluster to find it going nowhere.
By newer glow plugs do you mean 200 tdi ones?
I might be interested in the relay/timer route. It might be the easiest if not the only way to go.
Glow plug wiring differences ... Retrofit Defender Technical Discussions 44 January 16th, 2012 10:44 AM
Stuck Glow Plug navydevildoc Defender Technical Discussions 7 July 19th, 2011 02:39 PM
Glow Plug Relay and Wiring Ren Ching Wanted 0 January 21st, 2010 01:27 PM
Glow Plug Relay Michael Defender Technical Discussions 1 March 16th, 2006 02:28 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
