Glow Plug Light turn on when dome light is switch is flipped on - Defender Source
Old August 27th, 2014, 11:55 PM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
So this is weird. I assume there is possibly a bad ground maybe somewhere.
So i turn on the dome light switch is turned and the dome light does not turn on, but the glow plug light does turn on, but I don't think the glow plugs are actually on. Anyone else experience this ever? Also my hazards decided to just buzz and not work also.
There are a few wires that are not connected to anything. Is there sheet for the codes of what all the wires are? white with purple tracer = Ejector seat
Old August 28th, 2014, 12:17 AM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
google search should get you a more specific wiring diagram but it sounds like a bad ground to me...I had the weirdest things going on when I had a bad ground, warning lights glowing, turning off, not working etc. Attached is a wiring diagram for an '86 diesel mod ffr. Also, I have a thread titled Sell, Fix, or Find Help and on one of the pages is a Lucas Wiring color coding explanation guide....very useful.
Old August 28th, 2014, 12:31 AM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
Thanks! I tried google but the only examples i could really fined were 2002, 1997 and on, and series.
I would of thought it would of been easiest thing to find since there is such a following for them.
Maybe i just suck at googling
I also notice when my dome light is switched on and the glow plug light is on the clock dies. There maybe there is a short in the glows and they are taking all the power. Need a good multimeter. to start chasing this.
Old August 28th, 2014, 12:41 AM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
Here is the lucas wiring explanation. Look great.
Old September 9th, 2014, 06:27 PM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
Sorted it out. I decided to re-do most of the grounding points on all the accessories. I centralized all the grounding points onto an aviation terminal block that was grounded straight to the battery. No more issues!
dome light, ht, switch
Fog Light Wiring to d110 dome switch tebby Defender Technical Discussions 16 April 4th, 2014 01:17 PM
Diesel Ignition switch with glow plug tomaco1 Defender Technical Discussions 18 December 31st, 2011 02:31 PM
Can I use a Dome light switch for hella lights tebby Defender Technical Discussions 4 September 5th, 2009 11:12 AM
Glow Plug Relay Michael Defender Technical Discussions 1 March 16th, 2006 02:28 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
