Glow Plug Issues- 300 Tdi - Defender Source
Old July 9th, 2009, 11:01 AM
Mark McDonough's Avatar
Mark McDonough
Mark McDonough
66' IIa, 95 D 90 300 Tdi, 94,98 D1
Hey Guys,
Anyone ever run into a situation where the glow plugs have hung or partially seized up in the bores of the cyl. head? I have #1 and #2 (from the front of the motor) that were real nasty coming out. #3 was fine and #4 wasn’t bad either but never experienced this before. I used anti-seize on the threads last install a couple years ago and was just checking things recently and never have encountered this issue before. Once I did get the glows out, I did notice that these two bores were pretty carboned up vs. what I've usually seen.
Any input on this one?
Mark
Old July 9th, 2009, 12:38 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Why did you took them out ?
- Charles Eames
Old July 9th, 2009, 02:33 PM
Mark McDonough
Mark McDonough
Glows
Routine maintainence. After many years of running diesels, I've found that checking the glows every couple of years even if things are running OK is good practice. Many of the contemporary manaufactures use inferior materials. The side effect of this on occasion is the glows swell or worse, break off. This makes for nasty maintainence and operating conditions. So all routine but this time I think I caught something just startingto happen. Right now what I dont know is just what, so thats why the post.
Any help would be appreciated
300 tdi, tdi
300 TDI needs new glow plugs. Bosch or original Beru? sundogcwolfe Defender Technical Discussions 11 December 17th, 2009 10:36 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
