Glencoyne Engineering 200TDI Mounts - Defender Source
Old January 22nd, 2018, 01:46 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Some good news for a Monday morning. As many people will know, the high quality OEM spec engine mounts that I have been selling for several years, have now been unavailable for a few months after the manufacturer stopped making them. This was bad news for anyone with a 200TDi or older diesel Land Rover as the "pattern" mounts on the market are all as hard as rock and give major vibration problems, not just at idle but through the rev range.
I have been hunting round for an alternative and this morning received a pair of sample mounts which I immediately fitted to a 200TDi-engined vehicle. This is one I converted about three years ago and already had the good quality mounts on it. One of them had been softened by diesel leaking onto it from the injection pump. I already had test data from the manufacturer comparing their mount to the sample I sent them, from which you can see that on test the two mounts performed pretty much identically.
Switching from the old mounts to the new sample mounts produced a very slight increase in vibration, no more than you would expect with new vs 3 year old mounts. I then fitted a pair of cheapish mounts, I have been using these as a temporary solution as they are a bit softer than the ones sold by Britpart etc, so they are by no means the worst on the market. With these mounts fitted the vibration was horrible.
Conclusion - these new mounts are as good as the ones I have been selling for the last six years. They are British made, the same diameter as the original mounts. The only difference is that the studs are around 5mm longer which can make it difficult to get a ring spanner onto the nearside upper nut unless the stud is shortened slightly. Angle grinder, 10 seconds, job done.
I will now be placing a large order for these mounts which will be available shortly from my Ebay shop, 29.95 a pair including UK postage. Watch this space.
Goods news!
Old January 22nd, 2018, 06:11 PM
ghoregon
Greg H
1986 Defender 90 200tdi Ex-MoD
Originally Posted by AdamSanta85 View Post
Goods news!
Thanks Adam...been waiting for these to be available again to do my tranny mounts.
Sent from my P027 using Tapatalk
Old January 22nd, 2018, 06:13 PM
WK2Burner's Avatar
WK2Burner
Francis
1991 D90 200TDI
Nice. It was either these, or the mythical super hybrid ones that Robert spoke of in a prior thread.
Sent from my SM-N950U1 using Tapatalk
Old January 22nd, 2018, 06:22 PM
Naplm00
Matthew
I use the bearmach ones, very soft and work great..nearly no vibration.
You can flex the center rib with your finger
Old January 22nd, 2018, 07:47 PM
AdamSanta85
91' D90 200TDI
That's what I have in my truck too. I've just never had anything else so I don't know if this is as good as it will get or if can be improved
Old January 28th, 2018, 10:36 AM
AdamSanta85
91' D90 200TDI
They are back in stock. I just ordered a set of 4, see if they make any difference over the Bearmach.
https://www.ebay.co.uk/itm/Land-Rove...item46756a0f67
Old January 28th, 2018, 11:41 AM
Naplm00
Matthew
I'm waiting with baited breath!
Old January 28th, 2018, 04:42 PM
Matt927
Matt
1997 Disco 1, 1992 D90
Genuine rock hard LR mounts swapped out for soft and inexpensive BFM560 mounts from Bearmach, night and day difference.
Old February 10th, 2018, 06:38 PM
ghoregon
Greg H
I just installed a pair under my tranny (previously did the motor with Glencoyne mounts too). I should have done all four when I first did it. The tranny mounts really took the remaining vibration out. I was stopped at a light with music playing and worried that it had stalled because I didn't feel the motor at all...nope, it was still running. If you are considering new mounts, buy four of these. You'll be a happy camper.
Sent from my SM-G920P using Tapatalk
Old February 10th, 2018, 08:28 PM
AdamSanta85
91' D90 200TDI
Awesome. Mine came in the other day, maybe I can find time to install tomorrow. The rubber seems nice quality
Old February 11th, 2018, 10:09 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I just noticed they are on back order already.
Old February 11th, 2018, 11:02 AM
WK2Burner's Avatar
WK2Burner
Francis
1991 D90 200TDI
I wrote to them yesterday, 2 week backorder, 100 more sets coming in.
Old February 11th, 2018, 11:13 AM
1of40's Avatar
1of40
1of40
Adam, make this fun and do a Hula-girl myth buster YouTube test, before and after. A glass of water would prob work too, just not as scientific.
200tdi, engine, mount, tdi
1991 LHD 110 200tdi 5 door greenmountainrover For Sale - Vehicles 4 January 2nd, 2018 07:14 PM
Bearmach 200Tdi motor mounts....softer version Matt927 Defender Technical Discussions 6 November 21st, 2017 06:06 AM
Glencoyne 200Tdi Conversion Motor Mounts -Silent Running richord Defender Technical Discussions 13 August 20th, 2017 01:28 PM
200tdi engine mounts tomaco1 Defender Technical Discussions 3 January 23rd, 2013 08:13 AM
2.25L and 200Tdi engine mounts question Gkase Defender Technical Discussions 8 April 10th, 2009 08:53 PM
