Glass to spade fuse questions - Defender Source
Old January 2nd, 2016, 10:01 PM
burlsube
Nick
1985 110 CSW
I've started the process of changing over from glass to spade fuses. But it looks like the conversion isn't the 1:1 that I was thinking. There are two conditions that the spade fuse box doesn't seem equipped for.
1- Multiple wires coming into the OEM terminal - I am not able to get a good purchase when the two wires combined. Do I need a larger terminal to accommodate the gauge or make a new circuit?
2. There are a few circuits that have three wires going into terminals one side of the fuse and the other side has one terminal.
Pics are attached. Any help is appreciated as I am new to automotive wiring.
ID:	138374   Click image for larger version
Old January 2nd, 2016, 11:42 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
I'm having similar questions after switching to a blade fuse panel as well. I'm interested in what the experts have to say about these issues.
1985 Land Rover 110 3-door ST
Old January 3rd, 2016, 12:23 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
This tool makes great connections for the conversion
SARGENT Tools 1028 CT Thrift Open Barrel Contact Crimp Tool for 24-14 AWG https://www.amazon.com/dp/B00CIRFSEG..._4-kIwbK2ZGKF2
Old January 3rd, 2016, 08:19 AM
burlsube
Nick
1985 110 CSW
Thanks. I picked up a similar tool and it makes the process much easier. Guess I didn't account for these edge cases though.
Old January 10th, 2016, 06:23 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Get a ratcheting crimper...much better connections and a good stripping tool...took me about an hour to do the whole fuse panel switch with real nice tight crimps...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old January 10th, 2016, 07:54 PM
1/4" Spade Terminal For Housings (9, 14 & 28 Strand Wire)
Old January 10th, 2016, 08:15 PM
burlsube
Nick
1985 110 CSW
Thanks. Took a little longer than an hour but I just finished it up tonight.
Old January 10th, 2016, 08:52 PM
What fuse holder did you use there? Was it a direct-fit into the panel, or did you have to cut at all? Looks good....one of these days I need to do mine!
Old January 10th, 2016, 09:13 PM
burlsube
Nick
1985 110 CSW
I used a AMR3138 for the fuse box and replacement fuse box from ebay
The fuse block was a direct drop in with the new fuse holder.
Old January 10th, 2016, 09:53 PM
Best $100 you can spend on an early truck. Nicely done.
I like smart fuses with an led in them so when something blows and its a cold and rainy night all you have to do is remove the cover and there it is shining @ you eliminating any guess work and the need for a flash light. Whomever invented smart fuses must have owned a defender....
Old January 10th, 2016, 11:22 PM
87 D110 (Ruby)
here here....I have the kit to do it - and will do these
Old January 13th, 2016, 01:27 PM
RBBailey
RBBailey
1965 IIa
If any of you have used this... I have the fuse box from the '93 NAS 110, should I order one of these, or keep and reuse the '93 fuse box in my rebuild/rewire of the '88 truck?
EDIT:
Did you have any issues using that eBay seller, or coming from UK?
If anyone recommends another option for a replacement fuse box, what would it be? (I'm using the 6 point Blue Sea box for my accessories, and it will be mounted with my batteries under my seat box.)
Looks like you did a good job on this, makes me happy to know I will only spend 7-8 days on this job.... ...that seems to by my typical conversion time from normal job length to what it will actually take me to do the same job.
Project:
1965 IIa SWB
Old January 13th, 2016, 01:34 PM
burlsube
Nick
1985 110 CSW
The ratcheting crimper is a must. I purchased a cheap o on from Amazon, but it ruined a few crimps. I ended up with one from I Swiss which was much better. I also got some extra terminals to practice on before I moved up the real ones. The biggest challenge I had some figuring out the previous owners fuse box skullduggery.
Old January 13th, 2016, 11:12 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
These are the ones I bought...
Astro 9477 Professional Quick Interchangeable Ratchet Crimping Tool Set, 7-Piece - Molex Crimping Tool - Amazon.com
http://www.amazon.com/gp/product/B00...ilpage_o05_s00
Great investment..
Old January 13th, 2016, 11:34 PM
RBBailey
RBBailey
1965 IIa
Your truck was owned by M. Lucas as well?!
Project:
1965 IIa SWB
Old April 7th, 2016, 09:02 PM
and i'm in on this one now too....
Old April 7th, 2016, 09:42 PM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
Where's the best place to get all the smart fuses? Buy piece by piece at the local auto parts store? Online?
Old April 7th, 2016, 09:49 PM
http://www.amazon.com/Littelfuse-009.../dp/B0000TX800
Old June 19th, 2016, 08:12 PM
ghoregon
Greg H
1984 Defender 90 Ex-MoD
Nick,
Looks great. I have all of the tools and parts (I think). How did you end up handling the two into one instances? Were you able to fit two wires into the standard crimp or did you need a different crimp? I've got the Astro ratcheting wire crimpers if that helps.
Greg
Sent from my SM-T520 using Tapatalk
Old June 19th, 2016, 09:46 PM
burlsube
Nick
1985 110 CSW
I was able to force them into one, but I ruined a few terminals getting it just right. In hindsight I should have probably looked harder for the next size terminal. You can muscle it, but it takes a little practice.
glass
Fuse Box: Glass fuse --> Spade Fuse gonzanc Defender Technical Discussions 20 October 27th, 2016 11:54 PM
3 spade 110 diesel fuel sender with only two wires flananuts Defender Technical Discussions 10 February 4th, 2014 08:15 AM
60amp accessory fuse B blowing in main fuse box owen Defender Technical Discussions 5 March 31st, 2013 09:18 AM
94 ST Fuse Panel Cover mfreeman17 Wanted 0 June 28th, 2004 01:30 AM
Blowing wiper/speedo fuse like crazy....help! P1CR Defender Technical Discussions 4 March 11th, 2004 03:23 PM
