Glass fuse replacements - Defender Source
Old March 6th, 2016, 06:44 PM
generalcutter's Avatar
generalcutter
Daniel
1988 Defender 110
Anyone have a good source for glass fuse replacements? I can find some of them but some 2.5 and 17 amp hard to find?? Help!
Old March 6th, 2016, 08:04 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Spend 2 hours and replace the glass panel with updated blades...easy and cheap to do...the most expensive part was the the quality wire stripper and ratcheting crimper...there is plenty of wire to cut off the old crimps and strip and crimp new ones on...
ID:	144466   Click image for larger version
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old March 6th, 2016, 08:29 PM
generalcutter
Daniel
1988 Defender 110
Where did you get the slotted trays?
Old March 6th, 2016, 09:11 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Do a goggle search (like fuse replacement defendersource) there many treads about this. GOOGLE is your frend
Or you can just do this and not worry again
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 7th, 2016, 11:36 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by roverman2010 View Post
Do a goggle search (like fuse replacement defendersource) there many treads about this. GOOGLE is your frend Or you can just do this and not worry again
doubles as a bit holder lol
Old March 7th, 2016, 02:27 PM
hcdmueller
Chris Mueller
88 D-90
I just changed over to blade fuses and it magically solved some of my electrical issues. I had cleaned the contacts, so I guess the old fuse panel was starting to corrode where the wires were crimped.
ac, glass
Fuse Box: Glass fuse --> Spade Fuse gonzanc Defender Technical Discussions 20 October 27th, 2016 11:54 PM
Glass to spade fuse questions burlsube Defender Technical Discussions 19 June 19th, 2016 09:46 PM
60amp accessory fuse B blowing in main fuse box owen Defender Technical Discussions 5 March 31st, 2013 09:18 AM
Exact replacements for OEM speakers Kimos Defender Technical Discussions 6 December 21st, 2004 12:46 PM
Door hinge screw replacements - guidance paulb Defender Technical Discussions 4 September 22nd, 2004 06:51 AM
