Glass for van sides...alternatives? - Defender Source
Old July 30th, 2012, 12:46 PM
Hi all,
I have a 90 station wagon with the "blank" van sides. I have it on my list of things "to do" to add side windows as per the NAS SWs.
What are the alternatives for adding sliding or fixed windows? Has anyone retrofitted RV-style windows to the Defender van sides? Or is it best for me to use the genuine LR or Paddocks rip-offs?
I would rather not spend $400-500 on these if possible...
Old July 30th, 2012, 01:18 PM
Use the windows out of a fiberglass hardttop. I have one here with seal you can have for dirt cheap. They are the same size as factory sliding windows. If you buy mine and take it to a shop, they will cut a replica for cheap for the other side.
Old July 30th, 2012, 01:50 PM
hey ron, does the fiberglass van side glass use the standard defender window trim to hold the glass in?
(the kind with the two-part seal)
Old July 30th, 2012, 02:03 PM
It uses alpine window seal so I think the answer to your question is yes. Unlike the front windscreen, sides are easy to put in.
Old July 30th, 2012, 02:08 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
An episode of Wheeler Dealer did this very mod.
http://www.wheelerdealer.com/
Old July 30th, 2012, 02:48 PM
They used shit aftermarket windows.
Old July 30th, 2012, 03:01 PM
down_shift's Avatar
down_shift
Russell
They could have of used sheetrock for all I care, but the process to cut the hole remains the same. Trying to convince Ed that we’re available to chop holes in the side of his rig after a few beers at HH. I’ll bring the pneumatic nibbler!
Edit -- just realized my sheetrock reference probably came out wrong, sorry, no bad intentions. I started by saying MDF board because it falls apart when exposed to water, but then my mind jumped to the sheetrock disaster in FL that is making lawyers rich.
Old July 30th, 2012, 03:02 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I'll bring a grinder and a 5lb sledge, I am sure we can find a use for them.
Semper Fi!
Old July 30th, 2012, 03:06 PM
Grinder would actually work really well to cut the holes.
Old July 30th, 2012, 03:23 PM
Wolf Fabrication
Sterling Archer
'08 D3
You are a gluton for punishment. In the real world we would use an air nibbler.
Semper Fi!
Old July 30th, 2012, 04:38 PM
Thanks guys. I'm looking into having Dulles Glass and Mirror make up some fixed side glass with built-in tint.
Old July 30th, 2012, 05:33 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Advice Department.
When cutting the hole, don't even think about doing it any other way than a nibbler. As an example, a jig saw will inevitably snag and "stretch" your aluminum and you'll NEVER get the stretch/pucker out of it.
I'd cut the holes 1st and then have your glass company measure & fit the glass & gasket.
Personally (IMHO), I think the standard side metal panels are too thin and really need to be "beefed up" (thickened) in order to hold the glass and gasket in properly. As an example, the fiberglass tops, they are much thicker than the metal on your side panels.
Old July 30th, 2012, 06:37 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
My two cents...
I have fixed windows in my 110 and have always wished that there were operable windows in the rear to aid in air flow. Since you are going so far as to add windows you might want to consider that.
Old July 30th, 2012, 07:34 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Here is an option:
Name:	rear lift up.JPG
Discussion here:
http://www.aulro.com/afvb/90-110-130...der-wagon.html
MUDSUX
Old July 30th, 2012, 11:19 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Originally Posted by MUDSUX View Post
One of the vendors at Outdoor Expo 2012, Rover Trac's, was selling windows similar to these.
Old July 31st, 2012, 12:40 PM
wow, those are pretty cool....
Old July 31st, 2012, 01:08 PM
the rover shop
shayne young
man... those aussies have the coolest shat...
Old July 31st, 2012, 01:40 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
You could sell ice cream out of the back in the summer.
Old July 31st, 2012, 01:51 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I like the idea but don't know that they would help with airflow as I would be reluctant to leave them open while driving and definitely would not leave them open on the trail
Old August 1st, 2012, 10:04 AM
the rover shop
shayne young
I learnt in dusty conditions on the trail not to have any windows open..only have the front vents open... As long as you are moving forward the air pushes in with enough pressure to keep the dust from coming in other areas.. Not sure what you could possibly benefit from having the windows open.. I have the Mantec window guards on my camel 110 so I can't use these unfortunately... But one of these days I will have them on another one.. But probably when I get back to OZ...
glass, sides
Defender glass choices-lessons learned Overlander Defender Technical Discussions 1 May 14th, 2010 10:51 PM
POE Lift Gate and Glass TDI Guy For Sale - Parts 11 May 25th, 2006 05:02 PM
I need front winsheld,right fender black flare, rear door glass. Vadim Wanted 2 July 23rd, 2004 11:47 AM
windscreen glass & door skins mattdh Defender Technical Discussions 8 March 9th, 2004 08:23 PM
Series 88 roof top and sides kellymoe For Sale - Parts 0 January 27th, 2004 01:12 AM
