GFT MT 82 six-speed - Defender Source
Old October 28th, 2010, 11:30 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
GFT MT 82 six-speed
What is the word on the new GFT MT 82 six-speed manual gearbox in the new D90?
Will they mate up to the LT230 and the 300 tdi?
How are they for durability? I like its gearing.
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old October 29th, 2010, 12:07 AM
Not sure on adapting it to a 300 (question for Dave Ashcroft) but I too am a huge fan. Early production ones (07my) had some tolerance/noise problems but later ones shift like sports cars.
Old October 29th, 2010, 12:21 AM
bjf's Avatar
bjf
barry f
94 ST #395
Getrag makes great transmissions. I had a 04 mini cooper s and it had one. One of the best sticks I have ever owned.
Yes I am a fag for having a cooper s.
Old October 29th, 2010, 04:54 AM
ashtrans
Dave Ashcroft
long story but the answer is No, won't fit
Dave
Dave Ashcroft
Old October 29th, 2010, 08:26 AM
James Pierce's Avatar
James Pierce
James Pierce Jr.
Dave
Meaning it would require the new floor tunnel and bulkhead modification????
Old October 29th, 2010, 10:19 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I had a Getrag in my Jensen Healy nice trans
Old October 29th, 2010, 01:14 PM
turbodave
Dave C
1983 110
If you want to shift a MT-82, then swing by your local Ford dealer on your way home and drive a stick mustang... IIRC, the mustang variants, ford Transit and defender transmission all come from the same plant in Halewood
Here is a view of the puma driveline:
http://www.landyonline.co.za/specs/s...007_engine.jpg
And here is the 6MT1500 on Getrags website...
http://www.getrag.de/en/235
Compared to the R380, this is a fantastic trans - huge ratio spead (7.33 vs 4.39) compared to the R380 makes it ideal for engines with a wide torque spread - but less ideal for a road racer who wants short ratios.
I look at the above pictire of the Puma driveline, and see no reason at all why this couldn't be mated to a TDi. A new/modified flywheel housing and/or adaptor plate, and the usual flywheel/clutch combination that would be pretty easy to work out, and it'll work surely? It looks longer than the 380, so driveshaft mods, new gearbox mounts, and probably trans tunnel mounts are probably on the list, but I can't see why this wouldn't be a great upgrade for those running defenders who want a better driveline.
Old October 29th, 2010, 03:53 PM
If you are going to all of that trouble, you might as well stick in an NV4500 as the adapters exist.
Old October 29th, 2010, 05:48 PM
discotdi
Todd Miller
Land Rover
if you are going to all that trouble you may as well buy a "1985 rebuilt" Puma which seem to be popping up everywhere.
Old October 29th, 2010, 07:23 PM
There might be a slight difference in cost between those options.....
Old October 29th, 2010, 10:20 PM
dsh12
Daniel Hayes
Is the NV4500 a six speed with similar gearing?
------ Follow up post added October 29th, 2010 10:21 PM ------
The Puma drive line consist of what?
Dan
Old October 30th, 2010, 12:07 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
The NV4500 is a 200 lb. iron case fully synchronized 5 speed overdrive truck transmission that is found in 3/4 ton and larger GM and Dodge products. Nice transmission, nearly unbreakable, most commonly with 5.6 to 1 granny low.
Nice, but overkill for most any Land Rover.
AC Fan Speed Knob Missing...Argh! boshea Defender Technical Discussions 7 February 17th, 2006 09:55 PM
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
speed sensor wiring rcork Defender Technical Discussions 2 July 27th, 2004 09:44 PM
Help Speed Limiter evilfij Misc. Chit-Chat 10 May 7th, 2004 10:04 AM
