Getting rid of T-stat on a D2 V8 4.6 - Defender Source
Old December 1st, 2011, 12:47 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
My wife's D2 is not going to see cold weather
any time soon, so in order to improve cooling
capacity I was thinking about taking out the
thermostat.
Top radiator hose to engine top and bottom
radiator hose to water pump.
Thoughts ?
- Charles Eames
Old December 1st, 2011, 12:55 PM
defeyago's Avatar
defeyago
Santiago
´96 Defender 110 VGTdi SW County
You don´t take T-stat for any weather condition, only check for a properly working one and that´s it.
Cheers,
SANTIAGO
´97 Defender 110 Tdi SW
´04 Freelander Td4 5 dr.
´97 Alfa Romeo 146 TD (Sold)
´95 Volvo 850 GLT Estate
´94 Discovery Tdi (Webasto equipped)
Old December 1st, 2011, 01:06 PM
bad idea
Old December 1st, 2011, 01:08 PM
bjf's Avatar
bjf
barry f
94 ST #395
It sounds like you want to bypass the heater box but again not sure why
Old December 1st, 2011, 02:14 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
No, I want to improve cooling. There is a T-stat mod available
on D web, they move the thermostat from a lower position on
the circuit to an upper position, on the top radiator hose. The idea
is to get more flow.
What's the down side of taking out the thermostat, other than
getting the normal operation temperature slower ?
- Charles Eames
Old December 1st, 2011, 02:54 PM
The engine will run poorly and inefficiently when not at normal operating temperature.
If you are having cooling problems, you should fix what is wrong, not apply some poorly thought out bandaid.
Old December 1st, 2011, 05:16 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
It's not real problems yet, but it could be anytime.
I feel too often that i'm running on the edge, traffic
jam, A/C on all the time, hot temperatures all year
long. I'm just trying to find the more sensible solution
to improve the cooling capacity.
- Charles Eames
Old December 1st, 2011, 06:06 PM
Just do the mod on dweb with a 160 or 180 degree. You need a thermostat no question. There are a few fan options you can use from flexalite. The stock fan with the GM fan clutch moves a lot of air. Use straight water and water wetter from redline. This works well for me in the summer. You can add some hood louvers which don't look that bad.
Old December 1st, 2011, 09:36 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Ceramic coating to the exhaust manifolds on the 4.6 in my old 90 made a very noticeable difference. Among other things, I could actually open the hood without burning my hand.
Old December 2nd, 2011, 07:56 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I wrapped the headers already, I guess engine bay is
a little cooler, hard to say.
My plan so far is to get rid of cats and wrapped the pipes
all the way to the Y.
Also planning to change the A/C fan with two matched
puller.
- Charles Eames
Old December 2nd, 2011, 08:05 AM
I think you need to keep the catalytic convertors. hood louvers help a lot per 2 DII owners I know.
Old December 4th, 2011, 02:37 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
For a mechanical or a emission reason ?
- Charles Eames
v8
D2 4.6 coolant hose clamps JFD Defender Technical Discussions 0 January 16th, 2011 08:22 PM
4.0 to 4.6 parts? gtg067i Defender Technical Discussions 6 September 11th, 2010 08:40 AM
4.0 or 4.6 SHort Block needed for 2000 D2 WLDKGDM Wanted 0 November 16th, 2009 03:56 PM
Ecr 4.6 V8 Hoss Misc. Chit-Chat 28 February 11th, 2006 11:21 PM
3.9 to 4.6 1995 D-90 boxerhips Defender Technical Discussions 5 January 25th, 2006 07:20 PM
