Getting into gear, but not *moving*! - Defender Source
Old February 9th, 2004, 11:00 AM
chris72982
Hi all,
Been having an interesting problem lately: After starting up my D ('94) the beginning of the day, I throw it in reverse and get a lot of hesitation in moving it. Seems like something is sticking underneath. If I shift into 1st and move forward a few inches, reverse is no longer a problem.
Just this morning I'm having the same problem with 1st. Feels like I've got the e-brake on! Let it idle for about 5 minutes and everything is fine. Any ideas? Thanks.
Old February 9th, 2004, 11:04 AM
check the e-brake adjustment? maybe your clutch has lost some fluid? how many miles on your truck?
Old February 9th, 2004, 11:05 AM
chris72982
Forgot to mention above...
Letting the truck idle for a few minutes solves everything. Will check the fluids...I've got about 92k on it.
Old February 9th, 2004, 12:38 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Has it been cold, wet or snowing lately where you live? I know that here is Colorado sometimes moisture will get into the brake and when it freezes over night will cause problem with the parking brake
Maybe moisture is freezing somewhere in the parking brake and not allowing it to disengage as fast as normal?
Maybe the cold is affecting the way the parking brake assembly is releasing?
When you park it tonight do not engage the parking brake and see if you still have the problem in the morning do not forget to leave the transmission in 1st gear and chock the wheel so it does not roll away
vin
Gear ratios - 1995 NAS Defender? jam90 Defender Technical Discussions 3 February 19th, 2006 03:58 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
Speedo Gear Removal 48vphantom Defender Technical Discussions 2 March 27th, 2005 02:51 AM
Grinding into Second Gear? azdefender Defender Technical Discussions 4 March 9th, 2004 01:44 AM
