Getting a frame Galvanized - Defender Source
Old December 11th, 2012, 09:22 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Having a frame dipped on Saturday, any tips on the prep? Its already being blasted.
I also have a frame from my 1985 if anyone is interested, rusted in areas, but some parts are still usable
Old December 11th, 2012, 10:48 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Get the inside as clean as you can, so that the acid dip can thoroughly penetrate the interior nooks. Before buying a new frame I looked into repairing my original frame and in doing so, I found ~1" of sediment in the interior of the frame rails.
1970 SIIA 88, Sold
Old December 11th, 2012, 11:11 PM
I still need to adopt a shop class.
Old December 12th, 2012, 08:20 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I did a used frame that looked like it was rust free. It was a true 85 frame that had been sitting in covered storage. There was soooo much rusty flakes inside the frame. I did as good as I could to get everything out, vacuuming and blowing it out. When they dipped it you wouldn't believe how much came out. The company didn't like the finish and took the extra effort to put it back in the acid bath and re-dip it. The finish was much better but you could still see some of the rust flecks that came out. I would do it again but try to clean it up a bit better, if possible.
Land Rover 110
Old December 12th, 2012, 08:34 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Mine is a very clean 97
Old December 12th, 2012, 10:00 AM
There will be rust on the inside.
Old December 12th, 2012, 10:26 AM
Tom, if you can get it chemically stripped, that would be best. This will clean out everything, and I mean everything. There will be no rust inside. The only problem with any of this, when you are dealing with a "pre-enjoyed" frame or bulkhead or whatever, is places where the metal overlaps. No matter what you do; blast it, dip it, it will still have corrosion there. Water gets in there thru capillary action and rust forms. Since the plates are inseparable, the rust remains.
All you can do is prep it the best you can and hope it turns out OK.
I'd say a new galvanized frame is better, but maybe not since aftermarket ones are all over the place, quality-wise.
Old December 12th, 2012, 03:28 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Can you powder coat over the top of galvanizing?
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old December 12th, 2012, 07:48 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
yes.
-Jeff
Thanks Jeff. Is this a common practice?
Old December 12th, 2012, 09:05 PM
Not on land rover clearly ...
1997 Defender 90 NAS Station Wagon, Coniston Green, Galvanized Frame 74k miles Boone90 For Sale - Vehicles 24 September 15th, 2012 10:59 PM
MAWS claims another victim-Protecting Galvanized Frame MUDSUX Defender Technical Discussions 10 December 12th, 2009 11:43 AM
109 Galvanized Frame Coiler For Sale - Parts 1 December 29th, 2005 11:53 PM
I've Got A 97 D90 Frame That was just Galvanized ksteven Defender Technical Discussions 21 March 24th, 2005 11:22 AM
Want to Buy: D90 Galvanized Frame Steve Friedman Wanted 0 August 27th, 2004 12:28 AM
