Genuine trailer wiring hook up need pic Roadside Rob? - Defender Source
Old July 15th, 2009, 07:06 PM
Bought the $192 kit from RN and it is from a disco I. Needless to say I am unhappy.
They INSIST it is the same as a D90, but I can't see how the disco I bracket would mount on a D90 and it does not have D90 instructions on it and, IIRC, the D90 kit had a longer 7 to 4 pin adaptor wiring.
So, can someone with an original D90 with the trailer wiring (Roadside Rob?) can you post a pic of the correct bracket so I can confirm that RN is smoking crack and tell them to issue a call tag to come get it?
Ron
I found this pic, but it does not show the bracket very well, but it sure looks different.
http://www.defendersource.com/forum/...trailer+wiring
Old July 15th, 2009, 09:01 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Are you asking to see how the L-shape bracket that holds the euro-style trailer plug screws into the stock rear bumper?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old July 15th, 2009, 09:19 PM
Yes. I want to see what the bracket looks like. I believe the D90 is flat not L-shaped.
Old July 15th, 2009, 09:25 PM
MonLand
Loic Fabro
I won't see my truck until Friday night but from memory, I'd say it is L-shaped. Now, on more than one occasion my memory failed me..... And since I bent the bracket last time I went wheeling, I am probably seeing everything bent! ;-)
MonLand
1995 D90 NAS
1996 Discovery NAS
Old July 15th, 2009, 09:26 PM
This I think is the D90 bracket
http://www.defendersource.com/forum/...chmentid=19929
This is the bracket I have (give me a minute to find a link)
Can't find a link but it is L shaped.
Old July 16th, 2009, 01:36 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I have a 97 D90 SW, and the wiring harness I bought from the dealer had a round plug in that attached to a covered recepticle that was pre-existing near the filler neck in the wheel well. The other end of the loom was just loose "pig-tail" wires that I wired into a turn signal "black box" that I bought at Walmart. That device was wired into a standard 7 pin connector. I went with a 7 pin because I eventually installed a braking device for trailer brakes. I don't like the feeling I get when shoved around by a loaded trailer and the short wheel base of the D90.
Dennis
Old July 16th, 2009, 08:14 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
That's weird my truck truck has the mounting bracket on the bumper but no wiring for a trailer. I had to add that myself.It looks to me like the mounting bracket is apart of the bumper.
Jimmy Buffett
Old July 16th, 2009, 01:46 PM
Per Les at RN, you can't get the correct D90 original kit anymore. Rover superseded the part to the disco I kit and per ME the bracket is wrong and the 7 to 4 flat is too short. I returned the kit to RN and will just use the shitty Hoppy walmart one as it is going to be wrong anyway.
Old July 16th, 2009, 05:17 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Ron,
I have a couple of DI kits, one that was only used a few times and the other was taken out of a wreck and looks good but is of unknow status.
I think I also have a an extra rover to flat and the black rover plug.
Let me know if you would be intrested in any of the stuff and I will see what I can dig up.
Old July 16th, 2009, 06:55 PM
dave, pm sent.
Ron
Old July 16th, 2009, 09:44 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Ron,
My original one got smashed on the trail a couple of years back and the plug relocated to the crossmember. I don't have any idea what it originally looked like.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old July 16th, 2009, 09:54 PM
Rugbier's Avatar
Rugbier
Gustavo
Ron,
my 90 has a square looking one 4pin , I've tested it once towing a small trailer, I am not planning to tow, so if you feel like stopping by and remove it from the 90 it is yours.
NO SIGNATURE
Old July 16th, 2009, 10:14 PM
Gustavo, thanks for the offer. I think what you have is the aftermarket kit (I have that already box to four pin) so I am going to hold out for a proper d90 kit. I think dave lucas may have a solution for me.
Ron
Old July 17th, 2009, 12:26 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I have one Ron. Not sure if it is original but I know its flat with plugs going into it that are in a straight line. I will take a photo tomorrow.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old July 17th, 2009, 11:13 AM
Thanks Dan!
Old July 17th, 2009, 08:16 PM
ini88's Avatar
ini88
Daniel Marcello
I took some quick shots of the plug. is this what you are looking for? I can take photos of the bracket if I can trace the wires back tomorrow. been drinking a little bit now and not feeling like crawling under the truck.
ID:	20607   Click image for larger version
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old July 18th, 2009, 02:23 AM
Dan,
What I am looking for is a good pic of the bracket that mounts to the rear step bumper where the big 7 pin thing is. On a genuine kit there is an adaptor plug from that to the four flat plug you are showing.
Ron
Old July 19th, 2009, 08:13 PM
MonLand
Loic Fabro
D-90 NAS stock trailer wiring kit pictures
Here are the picture you wanted to see (well. actually only one is significant). I also took a picture of the adaptor plug for future reference).
Note that mine is bent.... I probably back into some rock a few weeks ago, but still works fine, so I'm not touching it! Clearance creates itself with time
ID:	20635   Click image for larger version
MonLand
1995 D90 NAS
1996 Discovery NAS
Old July 19th, 2009, 10:41 PM
Thanks Loic!
That is exactly what I needed. The one RN sells (the one for a DI) has a different bracket and the cord in picture 3 is shorter. Ergo it does not work right with a D90. Shipping it back to RN tomorrow with a print out of these so no one else wastes their time. Dave lucas has a used one I can make work with the long plug I have here.
Ron
Old July 19th, 2009, 10:53 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Ron,
If I remember correct you can make the plug however long you want by removing the old one and installing a new one.
genuine, wiring
Trailer wiring????? JEEPETR Defender Technical Discussions 3 July 13th, 2008 12:42 PM
wiring a trailer hook up jstrong98 Defender Technical Discussions 9 September 27th, 2006 09:51 AM
D90 trailer wiring JEEPETR Misc. Chit-Chat 1 August 3rd, 2005 11:00 AM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
If you don't have trailer wiring this is the ticket... wicks Misc. Chit-Chat 5 June 2nd, 2004 11:05 PM
