generic gaskets? - Defender Source
Old March 9th, 2006, 07:00 PM
vesparover's Avatar
vesparover
brian bertolini
generic gaskets?
Hey everyone, I just got in the gaskets for this 4.6 I'm putting together. I ordered from DAP and didn't specify oem gaskets. When I opened the box I realized some stuff was from Bearmach and some was just Generic looking. Any of you guys used these. I hate to put this thing back together and have a problem.
Brian Bertolini
Old March 9th, 2006, 07:36 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
To be honest, there just aren't many gaskets out there for the Rover V8 these days. The 'Generic' ones are most likely from Bearmach like the rest of them, or possibly by Payen, which is a division of Federal Mogul. Heck, my Payen gaskets all had Rover part numbers stamped on them, so I suspect they may actually do the manufacturing for LR. I used a set of Payne gaskets in my 3.9, and they have honestly held up better than the original ones did.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 9th, 2006, 09:08 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I used aftermarket gaskets on both my 4.6 and 4.0 and they work fine--I compared it to a new factory and they seemed identical in construction. I would not hesitate to use them again. On the same note, you can get aftermarket head bolts--I used them on both my rebuilds. They were about $80 for a complete set (maybe even less).
Old March 9th, 2006, 09:23 PM
Hans's Avatar
Hans
Hans Haase
Ahhh, head bolts. I used the ARP head studs, they ran I think $120 or so from Summit Racing (it's been a year, I forget for sure). As long as you stick with a known brand, you should be fine on the head bolts.... just don't re-use the old ones.
-Hans
My oil line fix
gas, gaskets
rear hub gaskets, Right Stuff & seal direction cdb Defender Technical Discussions 4 May 31st, 2009 12:01 PM
rear hub gaskets or Right Stuff cdb Defender Technical Discussions 1 May 30th, 2009 12:23 AM
Body Panel Gaskets Grover Defender Technical Discussions 1 April 30th, 2006 10:29 PM
4.6 block, which gaskets? vesparover Defender Technical Discussions 0 March 6th, 2006 07:17 PM
changed cam, all gaskets and now it won't run vesparover Defender Technical Discussions 4 July 24th, 2005 09:56 PM
