Generic Advice on What to Look for During Inspection - Defender Source
Old June 11th, 2013, 04:38 PM
Dragon Breath's Avatar
Dragon Breath
Jay
Blank
I'm doing a pre-inspection, insepction tomorrow (meaning if I like it and can agree on a price I will have pro look at it) before I buy. I'm wondering what sort of tell tale signs I should look for (I don't imagine I'm the first to ask, but couldn't find another thread on this subject) -- as good signs or bad signs.
It's a 94 ST, got about 75k miles, and has A/C. Spent 1/2 of its life in Colorado and 1/2 in California.
Old June 11th, 2013, 04:49 PM
Check all of the rust spots highlited in this thread. Bring a screwdriver and poke around.
http://www.defendersource.com/forum/...ad.php?t=45855
Then have a KNOWLEDGEABLE mechanic who has experience with Land Rovers (RRCs, D1s, Defenders) go over the truck while you also look at the following:
http://www.defendersource.com/forum/...ad.php?t=12367
Also, bring the car up to temp during a drive, then let it sit for 10 minutes while running while you look over the truck. Keep hood closed for now. Check for leaks, etc. Then check the temp gauge and see where it sits. The list can go on and on and on but rust, leaks, overheating, electronic (are all lights working and functionining?) are a good start. If the oil cooler lines (search) have not been replaced with braided stainless or upgraded (or deleted) then you'll want to replace those immediately if all else checks out.
Walk around look for dings, dents evidence of bodywork
Have door jambs been painted over, are tags and badges clean or covered with paint
Rust in door bottoms, general condition, body panels straight?
Under the hood:
Check inside of oil filler cap for color
Look for leaks and stains on engine
Backpressure in overflow tank from rad
check viscous fan
bulkhead rust? footwells?
leaks in tran cooler, oil cooler lines
plug wires genuine or better?
Serpentine belt condition?
Pulley wear?
Underneath
Check LT230 for play in front and rear output bearings, excessive play in Tcase
Check Ujoints for movement
Chassis rust?
Obvious repairs or welding
Condition of gearbox, leaks?
Exhaust condition, tap cats, do they rattle?
Look for evidence of exhaust leaks
Interior
Condition of seats
Pull back carpet is there rust?
Does odo match the condition of the vehicle
are the pedal pads worn a lot
Burns in carpet, seats?
Turn the key don't start
Do all the idiot lights come on?
Start
Listen to engine sounds, AC off, noises?
Do all the lights go off properly
Turn on AC
Squeel?
Cold Air?
Turn steering wheel back and forth
Noise, Squeel, Feel?
Clutch pedal feel right?
Brakes feel right?
Is the emergency brake adjusted properly?
Drive windows down, AC off
Noises, pull, power, does it brake straight
Slowly in parking lot turn both directions with wheel to lock, do the CVs clunk and clank, tire scrub?
Engage low range
Does it go in easily? Does diff lock light come on when engaged?
Drive in low, excessive noise or whine?
Drive normally, wobble or shimmy in front end, overall feel of vehicle?
Drive for 15 to 30 minutes
Park, open hood, engine running
Is engine too hot, is viscous fan working, any noises, everything in good nick?
Turn off engine
Tell the owner everything that needs to be serviced from what you have seen. Look at service history if available. Find out everything you can about who has owned, how many owners, area of the country (salt on roads in winter)
Make offer. Leave number and don't look back when you leave. Don't show up with cash! Don't become emotional. Don't buy any car that you cannot live without or you will pay too much.
Old June 11th, 2013, 04:58 PM
rust, service records, rust. Have a look in the oil filler, sludged up = neglect.
Old June 11th, 2013, 06:19 PM
Dragon Breath
Jay
Blank
Thanks for the excellent and thorough advice.
advice, inspection
Rover Inspection Help in UK Please?? Neo Defender Technical Discussions 7 October 16th, 2005 08:55 AM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
Advice Sought... cbass Misc. Chit-Chat 29 March 11th, 2005 07:56 PM
auto transport advice mdmccallum Defender Technical Discussions 6 May 11th, 2004 05:58 PM
any advice or comments ccrover Misc. Chit-Chat 6 December 7th, 2003 11:43 PM
