General Info: Wiper Control Positions - Defender Source
Old December 15th, 2008, 02:41 PM
pcscharfe
pcdefender
D90/NAS 110
Thumbs up General Info: Wiper Control Positions
Just out of curiosity:
The wiper control switch on my 97 ST has 4 positions:
#1 - (Start position) OFF
#2 - (Position #1 + UP 1 step) INTERMITENT
#3 - (Position #1 + UP 2 steps) CONSTANT
#4 - (Position #1 - DOWN 1 step) Nothing happens.
Is somehting supposed to happend when i am in the 4th position (1 step down from the Start position)? Is it a miraculous high-speed position that just doesnt work on my D90 (highly unlikely i know)? Or is it intended for the SW rear window?
Thanks.
Old December 15th, 2008, 02:50 PM
grnrvrs's Avatar
grnrvrs
Paul
88
on my 83 110, #4 is single wipe, return to #1.
Old December 15th, 2008, 02:55 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Stock is:
All the way down: INT
Next one up: OFF
Next one up: ON speed 1 (normal)
Next one up: ON speed 2 (fast)
Email:
Old December 15th, 2008, 03:13 PM
pcscharfe
pcdefender
D90/NAS 110
Thanks Mike,
I just went out the truck to double check -- and your explanation matches my setup exactly. HOWEVER, my INT/ "All the way down" position does not function at all.
Any theories why the intermittent poistion would not work? Just a bad control switch?
Thanks!
Old December 15th, 2008, 03:25 PM
ECR's Avatar
ECR
There is a wiper control timer unit down by the flasher relay (bulkhead fuse box). It likely went TU.
Email:
Old December 15th, 2008, 03:35 PM
pcscharfe
pcdefender
D90/NAS 110
Thumbs up
Gracias -- this is the one I assume? Part# AMR2341
Old December 15th, 2008, 03:52 PM
xrover's Avatar
xrover
Len Cater
1997 D90
Okay, how about wiper blades that change their sweep angle. I replaced the knurled holders for the blades. When it's running the driver blade works fine but it changes it's sweep so that at times half of it is off the window catching flies. Is this a motor issue?
'97 D90 NAS
'06 Argo Avenger
Wanted: wiper control cdnpaul Wanted 1 February 12th, 2006 05:45 PM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
