Gearshift lever will not go into gears! Help Please! - Defender Source
Old August 16th, 2009, 07:33 PM
e90miller
EMILLER
90
Gear shift lever will not go into gears. Transmission is in a gear and truck will drive/move, but gearshift lever does nothing but sway around! There was no loud bangs or strange noises. I went to drive the truck to the store and this happened. It basically feels like the shifter is no longer attached to the transmission internally.
Clutch? Transmission? Hydraulics?
Help/suggestions greatly appreciated!
Thanks, Erin
Old August 16th, 2009, 07:42 PM
Probably broke the level itself.
Old August 16th, 2009, 07:44 PM
e90miller
EMILLER
90
Inside the transmission? I pulled the boot off, stick is still attached at top of transmission
Old August 16th, 2009, 08:11 PM
Take the stick off. It is held on by four bolts I think.
Old August 17th, 2009, 02:50 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Take the stick lower casting off (4 or 6 bolts, as said above)
you'll see the selector rod sticking out of the gearbox with a "cup" on it, this is where the "ball" on the end of the stick locates.
This "cup" is held onto the shaft with an allen (hex) head grub screw, get a suitable sized allen key and (after relocating it in the right place) crank it up.
you should either see a mark or an indent on the shaft where the cup should normally live.
some threadlock on the grub screw can help too.
Old August 17th, 2009, 02:44 PM
JSQ's Avatar
JSQ
Jack Quinlan
I second the allen set screw on the shift linkage.
Old August 17th, 2009, 04:26 PM
e90miller
EMILLER
90
Just sucks the first set screw is tight. So it's probably the 2nd set screw?
New Gears and WOW, 10 mph? mdmccallum Defender Technical Discussions 26 December 1st, 2011 03:50 PM
Gears vs Tires jimbemotumbo Defender Technical Discussions 21 April 26th, 2005 09:23 AM
Name for gears. ripp2002 Defender Technical Discussions 3 February 8th, 2005 12:05 PM
Transfer Case Lever Thread Size? ronward Defender Technical Discussions 4 August 30th, 2004 02:26 PM
4.10 gears and Detroit locker dave_lucas For Sale - Parts 3 December 1st, 2003 03:03 PM
