Gearshift knob ball thing.... - Defender Source
Old July 9th, 2012, 12:29 PM
Flagg's Avatar
Flagg
Flagg
1995 Defender 90 NAS
Guys,
Stupid question probably......
My Gearshift knob is lose......keeps twisting. Anyone have recommendations on a cool one.
Also - how is it supposed to be mounted? How are the replacement once mounted? Are the threads of my plastic one just shot. Does it screw on - or push on and pull off. Should I just pull it off and glue it back in place??
All these parts are getting so rare - that I just don't want to pull or start twisting if I am going to break things worse......
Thanks for the advice,
Flagg
Old July 9th, 2012, 12:33 PM
The stock gear shift knobs "self thread" I think the term is - i.e. they're blank inside, but the threading on the shaft threads the knob. In the heat the threads tend to give a bit more as the rubber heats up. The t-case one is glued on from what I remember.
Old July 9th, 2012, 12:41 PM
Roversdownsouth has em
Old July 9th, 2012, 01:10 PM
Naplm00
Matthew
http://www.defendersource.com/forum/...ght=shift+knob
Old July 9th, 2012, 01:47 PM
Fill it with JB weld and thread it back on.
Old July 9th, 2012, 02:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
I used red thread lock and it finally doesn't spin.
Old July 9th, 2012, 10:52 PM
I ordered a replacement for $2 - yes, $2 - from Paddock Spares. Did the same trick as the genuine knob I put on the 110 for 10x the price.
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Rear Ball Joint Buckon37s Wanted 4 April 9th, 2006 06:54 PM
Dumb Ball 3000 Hillbilly Raider Trips, Trails and Events 0 February 14th, 2006 09:03 AM
Interesting swivel ball problem dameek Defender Technical Discussions 1 July 24th, 2005 01:18 AM
