Gears - Defender Source
Old June 5th, 2007, 09:28 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Gears
Took the truck swimming once to much, mud water ect acted like a grinding paste. Had it re-build and fitted it the weekend, starts now straight away. Dip the clutch and it wouldn't go in gear, stop the engine and its fine (still need the clutch depressed). Start again in gear with clutch depressed and it starts moving. Needed to move it so started in gear, reverse about 15ft and brake to stall it, clunk, bang and clatter and alls fine. Start it the next day and it clunked into gear, drove about 5 mls and all seems fine. I fitted a new cluctch about 5k mls ago. Any idears as to what is wrong.
The truck has been standing for about 3 mths.
3rd low and BOOT IT
Old June 5th, 2007, 09:35 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
After Driving it, Did it help at all. Might be a sticking and dirty clutch disk from all the muck...
Legend in My Own Mind.
Old June 5th, 2007, 09:50 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
was fine after a short drive, can't try again just yet, got a terrible wobble, can't keep it running straight over 25mph. just done the radius arm bushes an checked all the others, checked and re packed wheel bearings. i'm hoping the front wheels just need to be balanced. the weights took up a quarter of the wheel, now on one there is only half inch of weight. gonna get them balanced friday
3rd low and BOOT IT
Old June 5th, 2007, 05:27 PM
Mike's disappeared, Jimmy hasn't driven his junk in 3 months... what's the world coming to?
I don't know anything about the clutch on a defender, but your description sounds like the clutch is not disengaging. Could you have not installed the fork properly? Do you feel resistance when you push in the clutch?
charles
Old June 5th, 2007, 09:16 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Charles, See Mike last week, has a busy life now. almost got his truck running now, been off the road since about oct/nov 06. No resistance, fitted new clutch and had to fit another new thrust bearing bout 3mths later, been ok since. Think i'll stick with Randy thinking seeing how the starter was filled with mud ect. Hopefully have it on the road Sat so try it then.
3rd low and BOOT IT
Old June 6th, 2007, 08:55 AM
LRover's Avatar
LRover
J. Michael McCaig
Your clutch plate was frozen to the flywheel. Rust forms on the flywheel from moisture and the plate sticks. You are lucky it wasn't worse. I've had to peel the plate off the flywheel after pulling the trans on a series when nothing else would work to free it up. I had parked it about 6 months.
New Gears and WOW, 10 mph? mdmccallum Defender Technical Discussions 26 December 1st, 2011 03:50 PM
Gears vs Tires jimbemotumbo Defender Technical Discussions 21 April 26th, 2005 09:23 AM
Name for gears. ripp2002 Defender Technical Discussions 3 February 8th, 2005 12:05 PM
4.11 gears snuffer Defender Technical Discussions 13 June 5th, 2004 10:31 AM
4.10 gears and Detroit locker dave_lucas For Sale - Parts 3 December 1st, 2003 03:03 PM
