Gearing with a 2.5na - Defender Source
Old May 15th, 2014, 07:25 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Anyone running 1.22 with a stock 2.5na LT77 set up? I'm fairly certain my stock set up is 1.6 so I'm curious.
Clay
Old May 15th, 2014, 07:45 AM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Never heard of someone trying... But I can't imagine it would be very functional.
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old May 15th, 2014, 10:18 AM
1of40's Avatar
1of40
1of40
ThanksDave. I'm currently topping out at 62-63 mph on the flats with 235's so maybe I should be content. I'm assuming there's just not enough HP in a 2.5 to handle the 1.22 ratio.
Old May 15th, 2014, 10:29 AM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
A 1.4 box would be the better choice, inmho.
Old May 15th, 2014, 01:12 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Clay - I just came across this link while researching 5th gear/70mph RPM's for my OM617 conversion: http://www.grimmjeeper.com/gears.html
It even has LT230 and R380 in the drop down. LT77 info can be found here: http://www.keirhague.com/gearboxes.html
Terri Ann's site has some good info too: http://www.expeditionlandrover.info/gear_ratio.htm
Old May 15th, 2014, 01:17 PM
Ashcroft has a gear calculator with every possible Rover gear train.
http://www.ashcroft-transmissions.co...atio_calc.html
Old May 15th, 2014, 02:34 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You might find any taller ratio will over gear the limited performance of the 2.5.
RDavisinVA
Old May 15th, 2014, 02:40 PM
Nah. 1.4 works well. The engine pull nearly the same from idle as the TDIs and there is enough power for 5th on the flats. You should be able to hold 70 mph at sea level with a 1.4. The 1.6 runs out of engine speed before then. I live in the land of the ex-BATUS 2.5NA Defender. They are everywhere and have many hours behind the wheel.
1.2 is a bit too high for pulling off in 1st in a 110 (just like a TDI) and 5th ends up being too high for highway speeds with the NA engine.
Old May 15th, 2014, 04:02 PM
1of40's Avatar
1of40
1of40
Thanks Gents! This is going to be helpful.
Old May 15th, 2014, 04:23 PM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
I was speaking from experience as I drove an X-MOD 110 that had a 1.4 box installed for a couple of years in the Boston / Cape Area. It was a nice improvement over the 1.6 it originally came with.
Old May 15th, 2014, 04:58 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Forgot to add - I am running a 2.5NA with 1.6 lt230 but with 33" rubber. I haven't done much highway but around town and up to 50mph it is fine.
Best gearing calculator I have found FYI KevinNY Misc. Chit-Chat 2 October 9th, 2007 12:55 PM
Best gearing for 33`s? oldscratchggf Defender Technical Discussions 1 September 15th, 2006 03:28 PM
Tire/ gearing question oldscratchggf Defender Technical Discussions 9 September 2nd, 2006 10:01 PM
Tyres (again!) + a bit of gearing Berty Defender Technical Discussions 11 September 15th, 2004 03:52 AM
Disco Gearing in D-90? OCD90 Misc. Chit-Chat 7 May 28th, 2004 10:26 PM
