Gearboxs - Defender Source
Old October 20th, 2005, 08:54 PM
Tezab_42
Terry Bonner
Gearboxs
Hi, can anyone please tell me...
is the landrover 2.5 n/a gearbox [d reg] the same as the land rover 2.5 tdi [200 tdi] [k reg]
are they different ratios? if anyones got charts/graphs of the gears would be greatful.
Thankyou.
Old October 20th, 2005, 10:58 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Since you are in England I assume you mean transmission when you say gearbox. If I am right, then no, the bolts don't quite line up. This is what George told me in order to get me to buy a new one so I might be wronge. No idea about ratios.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 21st, 2005, 12:17 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Dude you need to get on the LRE forum. People there can answer your questions and direct you to parts in your area. While we would like to help you, you should make use of your local sources being in UK and all. Be sure to familarize yourself with the search feature here as well an ask more specific questions when possible.
Check ashcrofts site for answers to your gearbox questions.
Good Luck with your project
JP
legend in my own mind
Old October 21st, 2005, 10:07 AM
Tezab_42
Terry Bonner
FRE? whats the site to that, yea the transmission. yes the bolts dont line up as we had to modifiy the casing. im currently running the 2.5 n/a gearbox in with the 2.5 tdi engine. and i dont feel shes kicking out the power like she should...
Old October 21st, 2005, 10:17 AM
The LRE board is no longer active.
http://www.lrenthusiastforum.com/ubb...reads.php?Cat=
But you can also check here
http://www.landrovernet.com/forum
It's a pretty good UK forum, we are not sending you away, but the guys on these forums will know a bit more about the UK Rovers and where to get parts then we will.
Oh and Jim mentioned Ashcroft, they are a great company in the UK, check their site out
http://www.ashcroft-transmissions.co.uk/
Old October 21st, 2005, 10:24 AM
Tezab_42
Terry Bonner
Nice one, thanks for the help dw roots stay with d-90
Old October 21st, 2005, 10:45 AM
Gear ratios are here
There is a slight change in the gear ratios, mostly in fifth. It should be the same bolt pattern however. Rover used to sell 200TDIs as a replacement for the 2.5NA. The conversion kit did not require any changes to how the engine mounted to the transmission.
Click on theis link to download the conversion kit installation instructions.
Old October 21st, 2005, 10:49 AM
Tezab_42
Terry Bonner
Thankyou a big help :D
