Gearboxes... - Defender Source
Old July 13th, 2012, 08:55 AM
texrover's Avatar
texrover
Jason
Gearboxes...
Originally Posted by Red90 View Post
Yes, 68A....L is a Defender TD5 gearbox, so will only fit a TD5.
Should post the S/N of the LT77 as the specific series affects values.
Drat
What fits a 200TDi?
And where do you get that kind of info on serial numbers??
TIA
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old July 13th, 2012, 09:06 AM
I just moved this from a for sale thread to not hijack....
The 200TDI came from the factory with an LT77S which is the H suffix. Some data here: http://www.red90.ca/rovers/gears.html Any diesel Defender (long stick) LT77 will fit, but the later suffixes are stronger. Also the 200TDI version has better gearing.
You can also fit a 300TDI R380, but the engine needs to be mounted further forward.
The last option is the stubby bellhousing R380, which allows placement in the stock location.
Ashcrodt have a bunch of info on their site: http://www.ashcroft-transmissions.co...iewCat&catId=4
Pair of manual gearboxes cheap on Craigslist KevinNY The Flea Market 1 September 8th, 2010 02:49 PM
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
howling trans or Transfer case? Gkase Defender Technical Discussions 18 February 8th, 2008 11:08 AM
2nd grinding? Synchro? Burke Defender Technical Discussions 25 January 28th, 2005 04:09 PM
