Gearbox/Transfer Case Mounting Bracket Locations - Defender Source
Old December 14th, 2010, 10:15 PM
punter
1966 Series IIA
I've been running into a bit of trouble... my hard drive took a dump on me and I lost most of my tear-down photos for my 1984 D110 (3.5L V8).
I've got my chassis stripped down, cleaned, and powdercoated... the axles are about ready to go back in and the engine is almost ready as well. I just put the Chassis cross member back in and I'm looking at these mounting brackets, trying to remember where they were located.
The engine mounting brackets are welded to the chassis, but there are two more brackets that bolt on... as I recall they support the gearbox and transfer case. Attached are pics of the parts in question. Can anyone hook me up with pictures of how/where these things bolt in?
I think the bracket with the 4 holes in the base plate went on the gearbox or transfer case itself (the extra tang being for the transmission brake cable) and the one with the three holes went on the chassis (on the drivers side of the vehicle) but I'm not certain on that or on how they're oriented.
ID:	33980   Click image for larger version
Old December 15th, 2010, 04:45 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Assuming your truck is a RHD just for orientation.
The part in your 1st pic bolts to the T-Case (back of the trans if its an LT95) on the Passenger side using the 4 holes. There is another part not shown that bolts to the frame and the rubber mount fits in between them using the single hole you see on this bracket and a slot in the missing one.
The part in your 2nd pic bolts to the frame on the driver's side using the 3 holes. There is a plate that bolts to the T-Case not shown in your pic and the rubber mount fits between them using the slot in this bracket and a hole in the other.
Does that help?
Old December 15th, 2010, 08:09 AM
punter
1966 Series IIA
Does that help?
yep, it sure does... I'll snap some pics of the two pieces I believe you're talking about (as missing) later, to confirm that I'm on track.
Old December 15th, 2010, 08:25 AM
punter
1966 Series IIA
ok...
1st pic, 1st post: bolts to the T-Case (back of the trans) on the Passenger side using the 4 holes (the largest of the 4 brackets, with the additional tang for the transmission brake cable)
2nd pic, 1st post: bolts to the frame on the driver's side using the 3 holes (the larger flatter of the two brackets with 3 mounting holes)
1st pic, this post: bolts to the frame on the passenger's side using the 3 holes (the simpler of the two brackets with 3 mounting holes)
2nd pic, this post: bolts to the T-Case (the flat plate with 5 holes)
...am I tracking?
Old December 15th, 2010, 08:30 AM
punter
1966 Series IIA
wtf??? ...the other pic didn't load
Old December 15th, 2010, 08:33 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Here are some pics of my rebuild, a 1983 RHD 3.5 V8:
http://mudsux.multiply.com/photos/al...MEMBER#photo=5
http://mudsux.multiply.com/photos/al...LUTCH#photo=21
http://mudsux.multiply.com/photos/al...LUTCH#photo=22
http://mudsux.multiply.com/photos/al...lkhead#photo=6
http://mudsux.multiply.com/photos/al...lkhead#photo=9
http://mudsux.multiply.com/photos/album/15/Transmission
I can take more pics if you need.
MUDSUX
Old December 16th, 2010, 07:03 PM
you can download the factory shop manual for your truck from dozens of different sites, including mine.
The LR parts book for your truck would also probably be invaluable as it would have diagrams that answer these questions. Both can be bought on cd part number is LHP26. I bought mine from Expedition Exchange but they don't list it currently price is around $23 and saves a hell of a lot of head scratching. Probably worth its weight in gold for your restoration.
http://www.britpart.com/Accessory.as...ryVehicleRef=1
I have 26, 27 and 28 and use the hell out of them.
Old December 17th, 2010, 03:29 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Yes, those are the 2 missing brackets. There are 2 types of rubber mount. Older type has M10 studs, newer type has M12. Check the sizes of the slots in the brackets to see what type you will need. If the slots are big enough for the M12 then you can drill out the holes in the other 2 brackets to fit.
Originally Posted by punter View Post
ok...
...am I tracking?
ac, bracket, mount, rack, transfer case
Powertank Mounting Bracket, used crown14 For Sale - Parts 14 September 30th, 2010 12:52 PM
Flexalite 210 Fan Setup with Mounting Bracket TDI Guy For Sale - Parts 8 December 4th, 2008 08:00 PM
Shackle Mounting Bracket on rear for recovery point? graves14 Defender Technical Discussions 5 January 31st, 2008 03:27 PM
Hella 4000 Mounting bracket ini88 Wanted 3 November 28th, 2007 11:55 PM
Stock tire Carrier Mounting Bracket Joe P Wanted 2 September 8th, 2005 08:11 PM
