Gear shift rod angle - Defender Source
Old June 30th, 2014, 06:07 AM
richord
Richard Ordowich
1987/D90
I installed a radio in the a console (Iron Goat) in the dash and moved the rear wiper/ washer switch to the same console. When I shift into reverse my knuckles hit the wiper switch.
Is there any way to move the shift rod back or bend it back?
LT77 transmission.
Old June 30th, 2014, 12:31 PM
Heat up one of the bends with a torch and bend it away from the dash a bit.
Old June 30th, 2014, 12:42 PM
The shifter lever is easily removed by popping the shift boot and removing the nut that holds it to the shift shaft. The shifter is meant to be adjustable for a mans stature. If yours is hitting the dash it sounds like the previous owner may have been smaller and has oriented the shifter so it was more reachable. That said, also easily bent once in a vice as Dave says above.
Old June 30th, 2014, 12:56 PM
There is no need for a torch to bend one.
Heavy Duty Track Rod Kit with Tie rod ends $250.00 SafariHP The Vendors Loft 0 August 30th, 2012 04:20 PM
Defender 110 Tie Rod Steering rod change tjfslaughter Defender Technical Discussions 23 December 14th, 2011 10:53 AM
1998 range rover convertible one-of-a-kind 4x4 sut like hot rod street rod Capt Milks The Flea Market 0 December 2nd, 2011 07:06 AM
Equipe Panhard Rod and HD Track Rod Rugbier For Sale - Parts 14 March 23rd, 2011 09:27 PM
Tie Rod/Track Rod joint removal....aarrrrghh DNinety Defender Technical Discussions 5 October 24th, 2010 01:08 PM
