Gear oil on the rotor - Defender Source
Old September 17th, 2013, 11:48 AM
redrange's Avatar
redrange
Billy
96 Disco "Narlee"
I recently had an axle gasket start leaking on the front passenger side. Gear oil got all over everything creating a pull in the drivers side when I hit the brakes because the passenger side pads were no longer gripping the rotor due to all the oil. I took everything apart cleaned everything up put on new pads and while it doesn't pull nearly as hard it still pulls a little when I brake. I am assuming that is because Between the heat of the pads on the rotor I must've burned some of the gear oil into the rotor? . It was suggested that I use a very light grade sandpaper On the rotor and then hit it again with brake cleaner and clean it up more, which ill do again today. But Wondered if anybody else had come across this issue or had any other suggestion on completely cleaning off that rotor (if its even possible to get out all residual gear oil) without having to take it off again?
'94 D90 "HAL" & 96 Disco "Narlee"
Old September 17th, 2013, 11:51 AM
Brake clean on the rotor and a few hard stops.
Old September 17th, 2013, 12:54 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Or take it through the mud pit at the Cove...either one should work effectively!
Old September 18th, 2013, 04:07 PM
redrange's Avatar
redrange
Billy
96 Disco "Narlee"
Took a red Scotch Bright tuffy and almost a whole can of CRC to it. No more pull.
Staved off the mud pit...for now.
Old September 18th, 2013, 05:01 PM
I did suggest that .
Old September 18th, 2013, 05:11 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Make sure your breather hoses are clear. It may have been what caused the seal to give. I unscrew the fitting at the axle and blow forced air through it. If you get a pop followed by sprinkles you know you have a clogged pipe.
Clay
Red Line Gear Oil... Weldon Defender Technical Discussions 29 June 21st, 2010 12:53 PM
gear oil everywhere.. rover4x4 Defender Technical Discussions 3 November 30th, 2006 02:59 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
