gear oil everywhere.. - Defender Source
Old November 29th, 2006, 12:39 PM
lots of miles this weekend on interstate. I noticed an excessive amount of gear oil i suppose from the transfer case all down the passenger side frame rail (dripping off) and on the rear axle the rear spring etc. Ill try and post up a photo. But Im wondering this has happened in the past and i check things pretty consistantly and they are always full i think ive added a little to the t-case in the last 20k over filled it a little bit. Could running at high speeds for extended amounts of time just heat up stuff thats been seeping around the t-case and it get sprayed around after heating up. if anything it just sucks getting out and smelling stink ass gear oil. the wierd thing is i bet if i get under and take out the fill plug on the case gear oil will run out. Its as loud as its always been no changes. THat being said has anyone found a gear lube thats made the case more quiet??? 57k miles on the truck. how do you folks troubleshoot a clogged breather hose? Is it easier to just replace it?
Old November 29th, 2006, 01:57 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
You may want to also check the parking brake. The drum brake on these things can leak gear oil as well, and my spray it as it rotates. If it is leaking there you will need to replace the seal inside.
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old November 30th, 2006, 04:12 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
check the rear diff pinion oil seal, also check tbox and rear axle breathers if blocked they can cause pressurization and blow oil through the seals particularly on long road runs at highr mph
Old November 30th, 2006, 02:59 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
remember oil goes down & backwards
the breathers ha pull the banjo off the axel the clog is usually there
now drill out the little hole that will help in the future
Red Line Gear Oil... Weldon Defender Technical Discussions 29 June 21st, 2010 12:53 PM
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
