Gear fluid ..... - Defender Source
Old October 7th, 2005, 09:07 PM
Rover- Girl
Guest
Posts: n/a
Gear fluid .....
Will have the rover worked on tomorrow....I want to make sure they
use the best for my Rover as far as fluids...the parts I got myself from DAP !
1994 D-90
Brake fluid DOT... 3 or 4 !!??
Gear fluid, none synthetic...80 weight !!??
Thanks 4 any sugestions
Old October 7th, 2005, 09:18 PM
Dot 4 break fluid, I use the Lucas sttuff, it came recomended from Rovers North. For the diffs, swivels and T-case use 90 weight. I use Mobile 1 in the t-case and cheep stuff in the diffs and swivels because I change it allot. For the tranns use MTL I think, Redline makes good good MTL for the tranns.
Old October 8th, 2005, 07:54 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
I second Redline MTL for the manual transmission, good stuff.
Old October 9th, 2005, 05:25 PM
3rd the MTL
Gear ratios - 1995 NAS Defender? jam90 Defender Technical Discussions 3 February 19th, 2006 03:58 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
» Defender Registry
Maggie
rankar
Max
juddy
Add your Defender
