GBR Front Install - Defender Source
Old March 30th, 2011, 02:31 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
GBR Front Install
A friend was kind enough to set me up with 2 complete third members and HD rear axles. The rear seems easy enough to do but havent seen alot of info on doing the front.
On Disco-Web they have a write were you unbolt the tire rods and slide the entire swivel ball aseembly out enought to unbolt the axles and drop / replace the third member. Is this the same way for the Defender? Is there a better way to tackle this?
All thoughts will be appreciated.
Nick
Old March 30th, 2011, 02:42 PM
Cube II's Avatar
Cube II
Michele
1997 D90
What I did...simply unbolted the flange at the housing, and pulled the whole package all together with axle...
Just don't drop it on your feet!
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old March 30th, 2011, 02:53 PM
97-D90-736
Nick Vogel
Must be slower than normal today, but you lost me... can you elaborate?
Old March 30th, 2011, 02:54 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
This is what I did too. It's the easiest way to take it out and put it back together. Just unbolt the 7 or 8 bolts holding the swivel housing to the axle housing and pull it out about 4-6 inches till you feel it come out of the diff.
Those 7 or 8 bolts are 12 point and a pain in the ass unless you use one of those closed ratcheting wrenches
Old March 30th, 2011, 03:10 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Uh...maybe it's me being slow today...
Right, what I said.
Yes, it's what I did.
This is the most practical way IMO unless you want to strip the whole swivel ball assembly to bits and then remove the shafts...
P.S.
Daniel beat me to it.
Michele
D90 VNTdi
[O]===[O]
Old March 30th, 2011, 03:42 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
It doesn't take that long to pull the CVs and shafts and rebuild the hubs. When's the last time you replaced or re-packed your wheel bearings?
Old March 30th, 2011, 03:46 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
What Chris said, good time to repack hubs and put in new seals. if that has been done recently you can use the other method like this.
Old March 30th, 2011, 03:59 PM
97-D90-736
Nick Vogel
That was done less than 6 months ago. Everything is good on that side.
Old March 30th, 2011, 04:46 PM
Get a gear wrench and go at it (use a normal wrench to break loose the bolts first).
Old March 30th, 2011, 05:45 PM
NoVaKevin
Kevin
sold#1469
i need to find some friends like that.
GBR Front Axles/CV reelpain Wanted 9 October 18th, 2005 07:13 AM
Rovertracks HD front axles CV's & GBR drive flanges ToaDisco For Sale - Parts 8 July 4th, 2005 01:50 PM
Front GBR Extreme Duty 23/24 inner axles, D110 CV's and spindles w/ brass bushing lwg For Sale - Parts 8 February 9th, 2005 01:08 AM
GBR 4.75 3rds and Extreme front axle setup for sale billnsandi For Sale - Parts 2 January 4th, 2004 11:10 PM
» Defender Registry
Ovis
Conwayrover1
Broken
Z.G
Add your Defender
