GBR 4.10 vs 4.75 gears - Page 2 - Defender Source
Old January 25th, 2005, 03:44 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Is it just me or does the 95 have a rev limiter, and does the chip change, change this. I think mine cuts out at about 4800 rpm. Never seems like enough in first gear.
matt...
Old January 25th, 2005, 03:55 PM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
4800 RPM? I barely ever hit 4K on mine (on purpose anyway). You're just wasting gas and risking harm at that engine speed IMHO. These engines aren't designed to be high revving. But in any case, I've been told they do have rev limiters, and yes, it sounds like you are hitting it, and no, I don't think the chip will fix that.
Old January 25th, 2005, 04:54 PM
???? Rover V8s love high revs. They should be good to 6000 rpm. 4000 rpm is nothing. Can sit there all day long.
Old January 25th, 2005, 05:02 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Yes that is the rev limiter ( mine starts to miss at 4800 rpms also) and RPI chips will give you a little extra room there if you use their chips. They claim! I don't know about the other chips out there.
What they are doing is something like increasing the air and fuel to the engine which will give you 5-10% more horsepower therefore you don't need to rev as high. But I for one would not want the rev limiter disabled. They also claim to do away with the speed limiter. If you have aftermarket exhaust and a high flow air fliter then you may notice the difference. The ECU in these vehicles will not allow the engine to use the extra airflow gained by the upgrades and the chip will reprogram this. This is what I have found out thus far. If I am wrong (very possibly) someone correct me.
Check out: http://www.rpiv8.com/carbs-4.htm#identify
Old January 26th, 2005, 12:31 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Originally Posted by WhiteD90
If you have a 94 you can drop a disco speedo gear in and do the same thing. I think it brings you back to around 3% error with 4:10s and 35s...takes about ten minutes and is cheap.
Tis
How about 95? and what year Disco we're talking here?
World traveler
GBR 4.75 Ring & Pinion RedRhinoProducts For Sale - Parts 1 January 25th, 2005 02:16 PM
Rear 3rd Member w/ 4.75 gears and Detroit orlandog For Sale - Parts 0 October 26th, 2004 10:09 PM
GBR 4.75 3rds and Extreme front axle setup for sale billnsandi For Sale - Parts 2 January 4th, 2004 11:10 PM
4.10 gears and Detroit locker dave_lucas For Sale - Parts 3 December 1st, 2003 03:03 PM
Setting up 4.10 gears TDI Guy Defender Technical Discussions 4 November 23rd, 2003 05:17 AM
