Gauge - Which order is it anyway? - Defender Source
Old January 16th, 2008, 04:37 PM
Heathbarcrunch's Avatar
Heathbarcrunch
Heath Glassman
In-between Rovers
I am working on my 1994 D-90 and I would like to make sure my gauges are in the correct order before I finish replacing the rusty screws and replacing the bulbs. Could you confirm what the correct gauge order should be from left to right? Sounds like a simple question, but here is why I am a bit confused.
The workshop manual that I have on disk states that the order of the gauges on a NAS D-90 is the following: Water Temperature gauge, Tachometer, Fuel gauge, then Speedometer. [See picture 1].
I have only seen gauges in d-90s as the following: tachometer, VDO - Water Temperature, Fuel then Speedometer. [See picture 2].
I came across a 110 on ebay with the gauges in the order that matched the manual; Water Temperature gauge, Tachometer, Fuel gauge, then Speedometer. [See picture 3]
Which is the correct order of the gauges for NAS 1994 d-90? Any help would greatly be appreciated.
ID:	11686   Click image for larger version
The farther backward you can look, the farther forward you are likely to see.- Winston Churchill.
Old January 16th, 2008, 04:42 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Mine is set up the same as yours.. tach, temp, fuel, speed ... a lot of the workshop documentation for the 90s is for 1997s (at least all the RAVE cd's are) .. so some things are slightly different.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old January 16th, 2008, 05:50 PM
themaxx's Avatar
themaxx
Ade
94 ST
Is it me, or is the Tach and Temp in pic #2 two slightly turned to the left?
Old January 16th, 2008, 06:12 PM
artm
Arthur Maravelis
97 SW
Swap the fuel and tach - it's more correct.
Old January 16th, 2008, 06:31 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, they are both turned a little. I don't know why you would turn the tach but on race cars they often turn gauges so that normal reading is straight up so at a quick glance you know all should be straight up without needing to look at the face at all.
I think mine are the same as the 110 you saw on Ebay but I am not near the truck to confirm.
Old January 16th, 2008, 07:09 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
All my defenders are tach, temp, fuel, then speedo. For us fuel and temp are probably the most important. We can't go too fast and we downshift when it gets too noisy
Old January 16th, 2008, 07:37 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Holy crap that water temp guage goes to 265!!!
Is that for when you really want to see the engine melt down?
The other folks posted the correct order. You can't swap the tach into one of the lcoations though. I wanted it that may on my 110 years ago, but the tach is long and hits the steering column support so it can't go there. Can't recall what hole that is though... it was more than a decade ago.
Email:
Old January 17th, 2008, 01:35 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
thats hot man..
Old January 17th, 2008, 02:40 PM
artm
Arthur Maravelis
97 SW
You can't swap the tach into one of the locations though. I wanted it that may on my 110 years ago, but the tach is long and hits the steering column support so it can't go there. Can't recall what hole that is though... it was more than a decade ago.
If you're referring to the D90 then you're wrong. I have that layout - fuel, temp, tach, speedo.
Old January 17th, 2008, 02:43 PM
my 94 has the tach on the far left
Old January 17th, 2008, 03:30 PM
ECR's Avatar
ECR
I'm not wrong.
Do you think I don't know this stuff or something???
You have a 97 and that has a totally different tach than we are talking about here. Yours is much shorter and will fit in all the locations.
The original post was asking about a 1994 D90, hence my reply.
In a 1993 NAS 110 or 94-95 D90:
If you put the tach in the location next to the speedo the steering column support prevents the dash from going all the way back easily.
If you push hard enough you can cram the support between the tach mount and wiring plug but this basically jams the POS wire for the tach against the column support (a ground) making a nice place for a wiring short.
This is for stock 94-95 90s. If you don't have the column support or something it may be different, but if all the factory equipment is there and it isn't touching it sure is dam close to.
Images attached.
ID:	11697   Click image for larger version
Email:
Old January 17th, 2008, 05:02 PM
GYM's Avatar
GYM
Gary
97 SW
.....You have a 97 and that has a totally different tach than we are talking about here. Yours is much shorter and will fit in all the locations.
The original post was asking about a 1994 D90, hence my reply....
Mike:
Since we're in the general dash area, would you mind clarifying which "idiot" lights are supposed to temporarily light up when the ignition switch is first turned to the start position?
Is it the same for all NAS model years?
Thank you.
Old January 17th, 2008, 05:26 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
I'm not wrong.
do not mess with the Ecker... he will OWN you
diameter/thread of sending units for gauge upgrade jaherring Defender Technical Discussions 3 September 29th, 2005 05:14 PM
Gas Gauge fried alaskajgg Defender Technical Discussions 0 April 4th, 2005 11:38 AM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
