Gauge showing HOT. Is this hot? - Defender Source
Old September 17th, 2017, 06:17 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
I checked the temp on the block and hoses. Seems high. I'm far from being an expert.
Note: brand new hoses, water pump, thermostat, and radiator.
She runs perfectly when idling. Won't leave center gauge all day. Creeps near orange zone on highway after 15 minutes.
Thanks all.
https://youtu.be/UHh0eBlIcS4
Old September 17th, 2017, 06:41 PM
Naplm00
Matthew
Try massaging the hoses with the front if the truck jacked up to burp out any bubbles.
Also check ground of sender and gauge.
Check rad when truck is warm for cold spots (blockages)
If you have exhaust gas coolant tester ,try that for possible blown hg
Pull tstat and check to see if it's stuck half open/shut or just replace
No it isn't normal
Old September 17th, 2017, 07:32 PM
You say you checked and it seems hot. What was the exact temperature? First suspect is always the gauge.
Old September 17th, 2017, 08:02 PM
I'm convinced too that many overheating fears are caused by inaccurate gauge or bad sender.
Old September 17th, 2017, 08:04 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Thanks John. Check out the video above. I recorded it just incase I wasn't doing it correctly. Reading off the block show 217-238. Bottom hose 187. Top hose 167.
New everything--> hoses, thermostat, water pump and radiator.
People saying maybe air in the radiator? I'll try to bleed it.
------ Follow up post added September 17th, 2017 08:05 PM ------
In the video, I'm using one of those IR temp guns. Did I do it right?
------ Follow up post added September 17th, 2017 08:07 PM ------
No it isn't normal
Ok great tips. Thanks man!
Side note: New radiator might have warm/cold spots?
Old September 17th, 2017, 08:47 PM
Oh. It's a V8. Yes. Air lock probably. Measure off the thermostat housing and the metal tanks on the radiator. The hoses won't be accurate.
Old September 17th, 2017, 08:53 PM
On the v8's you have to pull the radiator plug out and fill till it comes out. Just adding to the overflow bottle doesnt get the system full. As said above, the upper radiator hoses are famous for creating an air lock and you have to squeeze the hose and force the air out with the truck running. Yeah 238 is hot.
Old September 17th, 2017, 09:05 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Ok thanks. Will do next weekend. Thanks for the tip!
------ Follow up post added September 17th, 2017 09:06 PM ------
Great advice. Thanks so much! I'll have an update next weekend.
Old September 20th, 2017, 07:52 PM
gmuiter's Avatar
gmuiter
Greg
1994 D90 #1646
Emissivity
Just a thought too - Inexpensive infrared thermometers dont usually have an emissivity setting. Not all objects emit infrared energy equally. The type of surfaces (e.g. metals, non-metals, transparent objects, hoses) and other factors can influence the amount of infrared energy that is emitted. (Also, varying distance between the object and the gun make a difference too)
This means if you are comparing the engine block to the black radiator hose, you could get two very different readings.
I would focus on the metal housing where the thermostat and sender unit are located. My estimation is this is the most accurate reading of the engine temp since that is where the temp sender is located and thus, the reading sent to your gauge.
Lastly, a previous reply stated about faulty senders....Couldn't agree more. I replaced three senders only to give up and put in the sender that came with my new VDO gauge. Now its spot on!
Good luck!
Edit: Oh and this last thought (quoted from member GWMckee): "if the [engine] temperature increases when not moving, there is likely an air flow problem... if the temperature increases while driving, there is likely a coolant flow problem"
Old September 20th, 2017, 08:08 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Distance makes a big difference with these. The laser is really misleading as it makes you think you're taking a "spot" reading with these IR temp gauges. The distance from the object makes a big difference in the reading taken. Mostly it's related to the "Distance to Spot" ratio. Basically it comes down to the area being read increasing as you increase the distance from the spot. It looks something like this:
Basically - Get that gun close and point it at metal.
Old September 20th, 2017, 10:30 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Make sure the sender is right, you could be the victim of a previous 'upgrade'
wing
Temp Gauge goes to hot on highway??? Help please! aircraftguy Defender Technical Discussions 8 May 25th, 2009 09:16 AM
diameter/thread of sending units for gauge upgrade jaherring Defender Technical Discussions 3 September 29th, 2005 05:14 PM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
